2,773 -
Posts posted by Gunther
7 minutes ago, PO4 said:
thank you for directing me to this post! I do not have a studio display.
I'm also not convinced it is solely a studio display issue. I think it's a resolution/graphics issue...
Are you running more than one display connected to your Mac Studio?
We have a bug into our engineers for this issue.
Thank you!
VB-185946 When entering Korean text, the last character typed, will duplicate when SpaceBar is pressed-
2
17 hours ago, mjm said:
@Gunther thanks for the info.
Is bug that slated to be corrected in the next update?
We have been able to duplicate the bug internally, though have been unsuccessful resolving the issue thus far.
Unfortunately, this is a current system limitation and the line thickness requires a range between 0.03 and 6.48mm. I can definitely submit an enhancement request for future consideration. Making changes in this area may have larger ramifications and not as simple as adjusting the values. Careful considerations will have to be made.
Curious, for what type of lasers are you creating output? The laser/software specifically requires .025mm line thickness? What kind of file are you exporting? -
@mjmThis is a known issue with some laptop users. You'll want to turn off Automatic graphic switching in your Battery settings for now.
2
56 minutes ago, Tismacfan. said:
No it is nog possible to log in in the upper-right corner. Its a dutch version 2.1 on a mac.
And the strange thing is it is not by every Mac user. So I think it must be something in the settings of the preferences.
Could it be resolved by delete net.netmetschek2022NL.plist?
I believe this may be fixed in a future update. In the meantime, check the Computer's Regional settings. You may encounter this issue if the regional settings are set to, English (World) and English (Europe).
17 minutes ago, Tismacfan. said:
Any idee how it comes that when you start up Vecotrworks 2022 you not able to login, so you can not use the VSS libraries. Is there a workflow to solve this?
Are you able to Sign-In, in the upper-right of Vectorworks, once the application has launched? If no, what happens? Is this 2022 SP2.1? Mac or Windows?
1 hour ago, Tismacfan. said:
It is one drive. Everything is setting as the buy the new computer.
Hmm, interesting. Are there any special characters in the name of the harddrive?
We have a report where installing to an external drive, "Mac Data" fails, however, "Mac_Data" succeeds. Perhaps its different for internal drives?
@Tismacfan.Does this computer have two drives by chance, one smaller drive for the OS and a larger drive for everything else? -
4 hours ago, Tismacfan. said:
Some customers get the message not enough disk space on mac, but when you look at it there is plenty of it.
how can this be solved to instal 2022 on a mac?Pascal
Does the name of the hard drive, have a space in its name? Try removing any spaces and see if that resolves the issue?
ok but it can not be the workflow to every 15 minutes restart Vectorworks
It often happens with Monterey en the M1 chip
@Tismacfan.Can you share a video? We received a similar report yesterday from a macOS 11.6 user and this may have nothing to do with Monterey, maybe just M1?
1 hour ago, Dondu said:
I have downloaded Vectorworks 2022, however, while I only just began using the program it kept shutting down midway through work.
I don't quite understand why this is happening since I have bought a new PC 2 weeks ago.
NAME OF PC: HP OMEN LAPTOP
Device Name: LAPTOP-9EQ3UF07
Processor: AMD Ryzen 7 5800H with Radeon Graphics 3.20 GHz
Installed RAM: 16.0 GB (15.3 GB usable)
Could someone please help me understand why this is happening?
All my updates are up to date as well.
I would start here:
10 minutes ago, Tismacfan. said:
After installing vectorworks 2022 and Monterey 12.1 I notice that sometimes the menu bar is blocked, I can't open any menu anymore, which makes working with Vectorworks impossible. In 2021 this will not be a problem. is this a known bug? How to solve.
Some users are reporting Vectorworks' main menu stops responding, mostly seen on laptops. Simply closing and reopening the lid, can temporarily correct the issue or going to your computer's System Preferences > Battery and turn off, "automatic graphics switching", then restart the computer.
If you're having issues with the main Vectorworks menu not functioning, closing and reopening the laptop lid, can temporarily resolve the issue. You can also try going to your computer's System Preferences > Battery and turn off, "automatic graphics switching", then restart the computer. This is something we're continuing to investigate and test possible resolutions.
29 minutes ago, Wesley Burrows said:
Ok, so I'm used to Vectorworks crashing at this point, but wow with SP2 it seems to be much worse, It used to be force quit (or the application would just disappear) re-launch and get as much work done as you can before the next crash. Now Vectorworks seems to be bringing my entire machine to its knees, have to physically power off. Completely unresponsive. This only happens using Vectorworks.
VW 2022 SP2 on Monterey 12.1 using 2 - 2K Thunderbolt Displays and 1 - 4k Vizio TV.
This happens during basic 3D modeling, push-pull, navigating, and shaded view walkthroughs.
Wesley, I'll contact you off the list to gather some additional information.
1
There are indications that macOS 12.1 resolves the multiple monitor issue, where the SaveAs and Export dialogs failed to display in Vectorworks 2021/2022. Some Adobe products were having the same issue. Waiting for further confirmation from the Vectorworks community, as we were unable to duplicate in-house.
1
We're hearing rumbles that the public release of Monterey macOS 12.1, may resolve the SaveAs and Export dialogs, failing to display issue in Vectorworks 2021/2022. If you update to mac OS 12.1, please keep us updated.
Pulled from another article on the subject:Adobe listed this same problem with Photoshop, Illustrator, and InDesign: “Sometimes the Save, Save As, and Export dialogs may not appear when an external display (via a USB-C Thunderbolt cable) or an iPad (via Sidecar) is plugged in. To display the dialogs, temporarily unplug the external display or sidecar. "
43 minutes ago, zeno said:
Hello Gunther,
on 2019-07-07 I did the VB-162563 "Zeno36_Videogame Mode on walkthrough tool don't works with 2 monitors" where I reported issues with the second monitor. The issue get the system uncontrollable, and the problem persist through years, moderate priority, unresolved, fix version "future".
Maybe is it connected to the same issue? Actually I have the same problem on my M1 but I did not reported it.
My English is bad now, 2 Yeats ago was a disaster, but I think you can understand the issue
No, I don't believe the two are related, even it multiple displays are being used.
41 minutes ago, SergeB said:
Since the newer Mac are using their proprietary chips, could it be an issue if I am not.
I choose not to because their ram options were limited.
Anyway, please be free to contact me if you need any info on my setup.
thanks,
regards,
Difficult to say at this point and something to consider.
27 minutes ago, SergeB said:
Yes,
I am using two displays.
And by disconnecting one it suddenly works. (?!?)
Thank you for the tip.
Will there be a service pack dealing with this issue?
many thanks,
We have been unable to duplicate in-house, making this issue difficult to resolve at the moment. We may contact you off the list for more information.
19 minutes ago, SergeB said:
Hi Everyone,
I also have an issue with VW 2022 SP2.
I am using macOS Monterey version 12.0.1
My computer is a Mac mini 2018 with 3GHZ 6-core Intel i5 with 64GB memory.
My issue is that I can't save, I can't save as..., and I can't export anything.
See attached video.
I was using VW 2021 and could not export. but I was able to save. I upgraded and it turned out to be worst.
Any suggestions please.
thanks,
Vectorworks Screen Recording 2021-11-25.mov
Do you use a second display or eGPU? If so, does disconnecting the second display or eliminating the eGPU resolve the issue?
1
@strYes, I have worked with a couple users from the forum independently and turning off, "automatic graphics switching" has help them also.
Thanks for the additional confirmation!-
1
On 11/20/2021 at 11:09 PM, Cody Worthman said:
Since updating to Monterey with vw 2022, I’m having issues with using the “Z” key to zoom. When I use the “z” key, the box that shows the magnified area is completely blank/void of line work and essentially useless.
This is the first I've heard of this issue. I gave this some quick testing and was unable to duplicate. I checked on design layers, rotated plan, sheet layers, viewport annotations, inside multiple views, and whiled editing a group/symbol.
Can you tell us more about your setup? What Mac are you running and video card if it applies. If you run multiple monitors, do you see the same issue when using a single monitor? -
Excellent @maxwellmeek! Thank you for trying and this gives us a great starting point for our investigation.
1
mac studio m1 max constantly crashes vectorworks & window server
in Troubleshooting
Posted
Thanks and please keep us updated. I've been testing on a Mac Studio with two displays 4K, one HDMI, the other usb-c and have yet to encounter the issue. Though, I'm not able to spend every hour of my day on the computer either. You're still running Ventura? It's my understanding that macOS 12.5.1, has helped many users with graphical issues.
