2,250 -
Everything posted by Gunther
This appears to be a Dell Alienware computer, correct? If so, see if there's a way to temporarily, disable the, "Dell Command Center" App and "Dell Support Assist" App and see if the crashing goes away.
@Sam Williams@Ryan Gann Are either of these Dell laptops by chance? Additionally, do you have any 3rd party applications running that are part of Windows StartUp? If so, I would try disabling a handful at a time, restart the computer, try Vectorworks again. If Vectorworks still crashes, re-enable items you turned off earlier, then disable more StartUp items, until you’ve exhausted the list. We have found for example the application, “NZXT CAM” running, causes Vectorworks to crash when switching workspaces, tearing off palettes and resizing the application window.
Locating Symbols in the Resource Manager
Gunther replied to willofmaine's question in Wishlist - Feature and Content Requests
Still no movement on my bug either and I'm finding others too. VB-165016 Texture Previews/Thumbnails Fail in 2020 When Texture is Created or Edited Inside a Symbol VB-168501 KLS: Edit texture fails In edit symbol mode I haven't checked in 2022 yet. -
Curious, if go to your compute's System Preferences > Energy Saver, is the, "Automatic graphics switching" option turned on or off? If it's turned on, try turning it off, restart the computer, make sure the preference remains off and try Vectorworks again.
Data Tag says no eligible object is selected
Gunther replied to Christiaan's question in Troubleshooting
Closest report I found and I don't suspect the wall is inside a group? Data tag: Cannot attach a data tag object to a wall or a door in wall if they are in a group -
I've checked with a couple sources and the output/workflow doesn't seem possible. Let me check with a few others...
@dcEchoHave you since moved to Vectorworks 2019 or is 2018 your current version of Vectorworks? You're welcome to send me the last six digits of your serial number and I'll review the crashes in our database. @michael john williamsI'm also interested in the crashes you've been experiencing. Anything you can duplicate at will, I'm quite interested also. Again, send me the last six digits of your serial number and I'll take a look. That's providing, "Error reporting" is turned on in your Vectorworks Preferences on the Session tab? Thanks!
@WrecktorworksPrivate message sent requesting more information.
Thanks for confirming @dtheory! This seems to coincide with an issue we're tracking. It might be worth working for a bit, with the Object Info Palette undocked to see if it helps for now?
Those having the issue, could you try undocking the Object Info Palette and see if the issue goes away? Can you also confirm this is a crash or hang (spinning beach ball)?
@fabricaThanks, I appreciate you giving those tools a quick test! Here's a weird thought, when you have a chance, try using the Drawing Label tool found in the Fundamentals workspace on a sheet layer for comparison.
Through another thread, we also understand you're having issues with a bloated user folder. It's through this thread, we realized your user folder is stored on iCloud. We do not officially support or recommend storing your Vectorworks user folder in iCloud, DropBox, etc. I would be curious to know if the drawing label issue and the bloated userlog file, subside, when the user folder is stored locally for awhile? It sounds like you might have tried this already and would just like to confirm. In regards to the Drawing Label causing a freeze. In a new blank document, can you try inserting a Column and/or Escalator object in a Design Layer, and let us know if you see the same freezing issue? Thanks!
Best to try the IP address of the server as Nicolas suggested. On rare occasion one of my Mac's cannot find the Site Protection Server automatically and using the server's IP address works every time.
Similar to what Jim Kelly suggested, try removing your user preferences and let Vectorworks generate a new set on launch. -On your keyboard, press Command+Shift+G -Type ~/Library then press Go -Go to Application Support > Vectorworks -Drag your 2012 folder from here, to your Desktop as a backup -Try launching Vectorworks 2012, you will be asked to activate your serial number again, if you're serial number begins with, "E" Please keep us updated.
This issue was fixed in Vectorworks 2011 and better tuned in Vectorworks 2012. The issue would happen when the, "Snap to Tangent" option was turned on in the Snapping Palette. I suspect the, "Snap to Tangent" was turned on within the Windows 7 64 bit computer but not your other Windows 32 bit computer.
Hello Everyone. For those of you having performance related problems, please send me your test files so we may investigate further. gunther@vectorworks.net To mail large files, compress the files first. Feel free to use something like, www.yousendit.com also. 1. Prior to sending the file, save the file at the point where the performance issue is happening. Meaning, if a particular sheet layer is having the problem, save the document with that sheet active. 2. Please provide detailed steps, on how to duplicate the problem once the file is opened 3. Let us know about your hardware. If you run dual monitors, what sizes? Thanks for your help Everyone! Gunther Nemetschek Vectorworks, Inc.
Vectorworks 2008 seems slow. Is this memory related?
Gunther replied to cdavis's topic in General Discussion
Gary, do you have iPoint.exe installed? Please see the following: www.formz.com/forum2/messages/16/18142.html?1169672089 -
Disappearing Drawings, is the a bug? 2008
Gunther replied to H2owe Green's topic in General Discussion
This is a known bug. I believe this happens when you drag-n-drop files on to VectorWorks. You may have better success going to File > Open. Gunther -
Please ignore my last question. The simple act of adding resources, closing and reopening VectorWorks is duplicating the problem for me. Initially, the names appear correct in the Resource Browser. Its only after the application is later re-opened that the problem appears to be encounted. I have submitted a bug for our engineers to investigate. Thanks!
Have any of you by chance renamed the VectorWorks 2008 application file? If so, rename it back to, "VectorWorks 2008" and see if the problem goes away.
We are in the process of investigating the printing problem on Windows. For now, if you turn of the GDI + Image option on the Display tab of the VectorWorks Preferences, you will be able to print. Gunther
Vectorworks 12.5.2 Crashes 10 times a day with NVIDIA software!
Gunther replied to petercard's topic in General Discussion
Peter, I believe you can just get away with turning it off. Uninstalling is not necessary. Let us know how it goes. Gunther -
Peter and others, I noticed that some of you are using NVIDIA video cards. There's an application called, "NVIDIA Desktop Manager" or similar, that is distributed with many if not all recent video cards. If you currently have the Desktop Manager running in the background while drawing in VectorWorks, please disable/close the application. The Desktop Manager has been known to cause random crashes in VectorWorks 12. Let us know if you have the Desktop Manager running and if turning off the application helped. Gunther Quality Assurance Nemetschek North Ameria -
VW 2008 problems saving to LaCie Ethernet Disk Raid
Gunther replied to nicholas's topic in General Discussion
Hello Nicholas. Could you tell us if you are connecting to the LaCie Ethernet Disk Raid 2 server with SMB or AFP? If connected using SMB, try connecting using AFP and see if the problem goes away. Please let us know either way. Thanks! Gunther Nemetschek North America
