2,552 -
Posts posted by Gunther
Bug officially assigned to Engineering for investigation:
VB-211068 Adding of cable break points with the context menu is slow in this file
15 hours ago, Mark Aceto said:
the drape objects will self-heal if:
- i drag them
- copy past them
- duplicate them
but if i move them back to where they are now, the black fill returns
@Gunther let me know if you need me submit a bug for this
You're welcome to submit a bug with a file and be sure to mention it could be related to the main topic of this forum thread.
Thanks!! -
Seems users of camera raw files are running into a similar issue:
Official announcement with more information:
Engineering is reviewing the supplied file and time it takes to add the cable breaks.
If I try to perform a break across 6-7 cables at a time, it does take my Windows 10 computer with Vectorworks 2025 Update 4 about 20 seconds to perform the action. It appears to hang, though eventually succeeds.
How long are you waiting before force quitting Vectorworks?
I'll keep trying... -
We're working on a couple public notifications. It appears Apple has broken some aspects of image handling in macOS update 15.4. We have reported the issue to Apple.
3
I was hoping dual monitor issues were a thing of the past, after all the issues we encountered with Sonoma from Apple. I have yet to hear this issue with Vectorworks specifically and checking with Tech Support for any similar reports. Searching the web in general, many Mac users encountered new dual monitor issues once updating to Sequoia. In most cases second displays are completely black or not recognized by the OS. Continuing to dig and ask around...
@Sam_UK Are you using a laptop? If so, the computer may not be switching to use the higher graphics option on launch.
Windows 11 has introduced custom graphics options for applications. It should not be necessary to add Vectorworks to this listing, though it’s worth a try if Vectorworks graphics performance feels slower or you have graphical issues.
-Close Vectorworks if it's running
-Go to System > Display > Graphics
-Browse to add the Vectorworks application file in question
-Then choose Vectorworks from the list below, followed by clicking, “Options”
-Choose the, “High performance” option and click, “Save”
-Try Vectorworks again to see if graphical issue goes away-
2
The command is not in the workspace editor - it is hardcoded and should always be available. The only cases it wouldn't be there are:
-The user is not currently using a Design Series license
-The object is already styled
@Pat Stanford When time permits, would you mind submitting a bug with your Designer workspace that's not displaying the command? Please share any past history with the workspace that you recall and we'll take another look.
Thanks!! -
I have confirmed Migrating a stock workspace (in my case Designer/Design Suite) from 2016-2024 into 2025 retains the context menu, "New Roof from Unstyled Roof" command. Best I can tell, the command is not being removed, if it previously existed. Which points to Patrick's comment, the issue may stem from using an earlier workspace where the command did not previously exist. I'm not aware of a way to add these command via the Workspace Editor and let me see what I can find out...
We'll be curious to what you find. Possibly a support file from 3rd party software is overwriting the same file we install, just a different version?
Thanks for the additional notes @AlanW
By chance, do you still have the install of Vectorworks that fails with the mentioned menu items? If so, I'm curious if a, 'Repair' would restore their functionality?
If you still have the install:
-Open your Vectorworks application folder
-Open the, "Vectorworks 2025 Install Manager" folder
-Launch, "Vectorworks 2025 Install Manager.exe"
-Refresh/update if asked
-In the upper-right corner, click the three line icon (hamburger) and choose, "Repair"
-Try those menu commands again once the repair is finished -
I'm curious to know what happens when you attempt to execute the commands you mentioned. Do you receive an error, does it do nothing or...?
Can you confirm the issue is on Mac or Win? -
The issue will be resolved in a future Vectorworks task.
For now, users can go to System Properties > Advanced System Settings > Advanced > Settings and uncheck, "Show shadows under windows" and will require a Vectorworks restart.-
2
12 hours ago, Jezzer said:
Same issue here using OS 14.4.1. with Vectorworks Architect 2022, not being able to handle larger files and then once I excited the file the menu will not appear on reopening the files. I had to restart multiple times in order to get the main menu. Once open I tried to keep VW open until the next crash otherwise the game of restarting the macbook pro over and over until it cleared itself and open the menu correctly. I will let you know if the update for 14.5 works any better.
In regards to the main menu missing, this is a longstanding macOS bug with Intel-based machines with two GPUs.
It can be fixed by disabling the Automatic Graphic Card switching option in power saving OS preferences.
1
On 4/26/2024 at 1:28 PM, JH21 said:
Ever since I updated my MacBook Pro 2018 to Sonoma 14.4.1 and tried to work with Vectorworks, the screen just went black and the keyboard still worked. Since I didn't know at the beginning (about 3 weeks ago) that it was related to Vectorworks, I thought it was a macOS error. I then took the problem to the Apple Store who had no solution to the problem and finally told me my laptop had a hardware fault, which in retrospect made little sense, but I trusted the "professional" opinion of the salesman and bought a new Macbook as a result. Macbook Pro16 inch. Unfortunately, I still have the same problem, only now the entire Mac crashes as soon as Vectorworks and a few other programs are opened in parallel. Is there already a solution for this problem? I have already informed Apple about this several times and they tell me to wait until the next update comes, but unfortunately I don't have that time. I would be grateful for any information that would make my Vectorworks run reliably.
We've seen this issue now internally and have reported to Apple.
Would be curious if the suggestion mentioned above by jdlang19 helps in your case for now?-
1
If you'd like to make the file available or message me the file directly, we'll take a look.
In the Document Preferences, you might also try turning off, "Display out-of-date border", close the preferences, reopen the Document Preferences, turn the preference back on, to see if it refreshes the border?-
2
On 4/19/2024 at 1:45 PM, Leon You said:
This sounds very similar to the graphic switching issue from years ago. Not sure why it would show up again after a macOS 14.x update, unless the update reset the battery option? Try going to your System Preferences > Battery and turn off Automatic Graphic switching option if available?
29 minutes ago, astephens said:
Yes, that's correct. I was setting up and testing vectorworks to get that laptop ready for another employee. I erased the hard disk and did a clean install of 14.4.1 and then downloaded a new copy of vectorworks. I realize now that I did all of that testing while not hooked up to an external display. That said, the recipient of the M2Max laptop has been using it for several days, with an external display, and has reported no issues.
Also, in case it's relevant, I use a thunderbolt connection to my external monitor. That was the case for the M2 Max and the new M3 Max laptop.
Thank you for confirming and mentioning the cable usage. I seem to recall in various Internet threads (not just Vectorworks), that cables for displays and other accessories were the source of their various problems.
1
15 minutes ago, astephens said:
OP here. Just wanted to give an update. I finished the workweek on the older OS and then over the weekend I erased my laptop again, did a clean install of Sonoma and then reinstalled vw from a new download. My system has been working ever since then. I wanted to confirm that I use an external monitor (Samsung M8) as an extended display.
I also had a new M3 Max MacBook on order that arrived in the middle of my dealings with the machine from my original post. It arrived with 14.4 installed. I got it set up and working and after a few days (and a Time Machine back up!) I went ahead and did the update to 14.4.1. That system is also working well, with the minor exception of a zoom/ vw issue that very occasionally causes zoom to crash when screen sharing vw.
This was prior to the announcement from Vectorworks advising users not to update. The new machine is working well, but I also have a backup that can restore to the previous OS version if I run into any more issues.
Just to confirm, your original system has been updated to 14.4.1 also, with no issue thus far?
Just now, bjoerka said:
Correct. When i directly go into the page setup, there are only standard page sizes available for the Canon printer.
Didn´t recognize this...
The Page Setup command in Vectorworks isn't ours, we just call the command from the OS. It's no surprise Vectorworks and TextEdit have the same issue. I've seen the same in Adobe Acrobat, if you choose, "Page Setup" from within the Print dialog.
1
1 hour ago, bjoerka said:
Hi Gunther, that looks different to what i see when i select our Canon large format printer.
In TextEdit i can select all page sizes that are available for the Canon printer.
In Vectorworks i only see what is available as if you print to a standard printer or i.e. pdf writer.
page setup in Apple´s TextEdit
page setup in Vectorworks...
Your screen capture for Apple´s TextEdit, looks like you went to the Print command. What if you select the Page Setup command, do you still see the expansive list or a reduced list?
1
2 hours ago, bjoerka said:
That is what Marc Wittwer in Switzerland also said.
But in my german localized version of Sonoma all Apple application show the paper options for our Canon large format printer .-)
Here's what I'm seeing on a Apple M1 Mini with TextEdit. Regardless of printer, Page Setup shows the same page options. When you go to the Print command, you'll see the Epson printer offers a much larger selection of page sizes. This large list of page sizes should also be available in Page Setup. Perhaps it's only some printer manufacturers having the issue?
Right Click on Freezing VWX with Cable Tools
in Entertainment
Posted
@KevinF1973Okay, your issue definitely sounds different compared to the delay I was encountering. The bug I mentioned previously will be resolved in a future update.
If you can duplicate at will, this longer stall, a video would be great and we can test further.
