AGPD
    5
Reputation
1 Neutral
Personal Information
  • Location
    United States
Recent Profile Visitors
  1. I have gone into each of my classes and unchecked "link pen opacity" and hit ok. When I go back into the class it is checked again. For some reason it isn't keeping the selection. Running Macbook Pro Ventura, Vectorworks 2022 SP6
  2. I did just figure it out. My none class visibility somehow got switched to grey when i imported that image. Switching it back to visible seems to have worked.
  3. I imported a JPG image into a layer. When i am in that same layer and I select the wall tool (I am tracing over a pdf floorplan) all my imported images disappear. To get it to come back i have to force select it. It then switches the class back to none. Is this a class issue? Even the lines i drew disappear... I have been working in this file for months and have other images in it and have not had this issue. It seems to do this whenever I switch to any other class. I am in the same layer, so i know that its not two layers with different scales. Any thoughts? Is this a glitch? I am running 2022 and am up to date.
  4. AGPD
    Reshape Tool
    For some reason when I attempt to add a vertex, it always adds a corner and will not let me change it to a radius vertex or if I select a vertex that connects two radius vertices, it changes the two to corner vertices. Perhaps I am using the tool incorrectly but I have watched videos and cannot seem to figure this out. I just want a polyline with only radius vertices. Using VW 2022
  5. I use the space bar to jump to the pan (hand) tool very frequently. All of a sudden it stopped working. It flickers the the hand for a second and then goes back to the arrow. Please help! This is a crucial short cut for me. Currently using VW 2022.
