Sam Williams
    9
Reputation
2 Neutral
Personal Information
  • Location
    United Kingdom
Recent Profile Visitors
  1. Can i email the file to you? Don't want to post publicly. They objects work for me within connect cad but not when plotted is that what you mean?
  2. Hi All, I have a VW CC Project where arrow connectors are not creating hyperlinks. (When plotted) - it navigates to the other end just fine in CC.. Both ends of the arrow are within the area plotted as part of a viewport. all classes are visible. I also have the PDF export settings set to enable hyperlinks (Required to create the arrow linking) But when i publish the drawing set i get zero arrow connectors. i have tried looking in many PDF viewers and they are just not being created. I have tried a few things but had no success. I am publishing to PDF.
  3. Hi All, When drawing Networks with Data panels and patch links between them, Typically / as a rule i always design these systems with 1.1 patching and not any of this data center non planned data distribution you see in some of the corporate network work. As such, i obviously want a cable number on the site cable into the patch. However i don't want a cable number on the patch lead between the panel and the switch. How do you currently achieve this? My initial thought is to create a new signal type called Cat6a Patch or LAN Patch.
  4. Turns Out this is an issue between Top View and Top Plan View. Use Top Plan and not Top.
  5. Can this be resolved by saving a block to the library and then re-defining a block but reinserting from the library?Can this be resolved by saving a block to the library and then re-defining a block but reinserting from the library?
  6. Hi All, The reference grid on a file i have been working on has changed to approx. 1020mm apart, yet the snap settings are still every 4mm apart as default. The grid settings are set to 4mm snap and 16mm grid as the standard CC Template. Page size is 50m or so in either direction so that's not an issue. The grid is visible and the grid turns on and off as it should do. The scale is 1:1 and i am in top plan view and wireframe view. The background is now a slightly lighter grey and not the true black i had before. but no idea why. If i create a new file, its all fine. But i don't really want to move all my content and layer over etc. Any ideas?
  7. Hi, I have the problem that with tail connectors which may flip upside down i can use the flip command to rectify normal instances of the connector label being upside down. However, where i have a network switch with all outbound 1G Ports on the right and 10G Ports on the left. When connecting switches with 10G ports, one will always be upside down due regardless of flipstate. Also when using network devices, where Lan ports are on the left side of the device the connections show correctly. However, when using Lan ports on the right side of the device. (where we use the right side of the network switch) one side is always upside down. I cant always show a Lan connection on the left hand side - Primarily on system input endpoints as the Lan port is actually an output. How do i fix this? (Don't say put the connector on the left side of the device)...Please
  8. Same issue here with a Dell Alienware Machine. Resizing the desktop crashes the software. Pretty much essential on a 32:9 Display. I am also using Powertoys. Although this isn't causing the crash. This is Similar to the situation from the initial release for VW2021. I Would benefit from this being resolved quickly this time round, as i would like to use VW CC on a project to start using is as a replacement for Autocad and reliability will kill it.
  9. I have the same problem here. It just closes itself regardless of any update. Clean install straight from the portal. Machine spec exceeds the minimum requirements: Processor Intel(R) Core(TM) i7-10870H CPU @ 2.20GHz 2.21 GHz Installed RAM 32.0 GB (31.7 GB usable) System type 64-bit operating system, x64-based processor GPU - RTX3070 8GB Edition Windows 10 Pro Version 21H1 OS build 19043.1237 Experience Windows Feature Experience Pack 120.2212.3530.0
