DFlores
    9
Everything posted by DFlores
  1. Hello, I copied it to a new file and the problem remains in the new file. I can change the stitch but the volume doesn't follow the line. When I start a new drawing and draw a curved wall it works however when I copy it and place it in my drawing it loses its shape Note: Works on straight walls!
  2. Hello! Hi, I have the same type of problem...does anyone know how to overcome the issue? Any suggestion? Thanks,
  3. Hello, I now have VW 2023 and the problem is the same. When editing countours from site model, vectorworks simply crashes and exit. Any answers to the problem? How can we adjust existing surfate without this feature to correct DTM before using the site modifiers to define the final surface! Thanks!
  4. @GuntherUnfortunately turning off the antivirus did not solve the problem! I keep getting the same errors and blue screen!! Any other suggestions?
  5. Thank you for your help. The download was carried out through the Portugal customer portal. Had installed an earlier version of the VW with no problems. To avoid possible conflicts, I removed all previous versions of the program. The problem remains... I tried to carry out the suggestion but an internal error occurs in the installation! Any other suggestions?
  6. Hello I recently upgraded to VW 2023 and I have the same problem as @Lisar. 1- after installation there is a plugin error VGS_Directlink.vlb "Plugin are not compatible with current version of vectorworks" Strange I suppose that it was installed by the vectorworks 2023 installation pack available on the website! 2 - Asking to continue the VW opens but after +- 30 minutes of use it mysteriously disappears without a trace!! Sequential consequence blue screen of windows and system reset. I have already performed the various operations left on the forum namely those posted by @Gunther but unfortunately without success. I've already reported the problem to technical support but so far I haven't gotten a response that solves the problem (points 1 and 2). Can someone help! DELL XPS 15 9570 Processador Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz 2.21 GHz RAM instalada 32,0 GB (31,7 GB utilizável) NVIDEA GeForce GTX 1050 Ti With Max-Q Design (controlador 12/10/2022 Edição Windows 11 Pro Versão 22H2 Compilação do SO 22621.819
  7. Hi, I have the same problem. Any answer to the problem, or way to avoid it? Best Regards
  8. Easy solution that works for me... Go to the pull down menu: Tools > Options > Vectorworks Preferences Then select Display and check the box -Show other objects while in editing modes Best regards,
