Dagny
    7
Reputation
1 Neutral
Personal Information
  • Location
    Norway
  1. I searched the forum and found out that I could try to turn off the graphics caches, and that seemed to be helping
  2. Hi I have problems with my drawing slowing down when I am editing annotations and moving viewports on the sheetlayer. I am working in VW 2023. I don´t believe it is a very complex drawing, the file is 112Mb, and I use Mac Apple M1 max. Does anyone know what I have to do to? I have imported a lot of elements from a sketch-up drawing, and I have used som elements from the resource palette. It is a drawing containing lots of differents elements for a set-design, and I wonder if I should "split" the drawing, and start working on some elements in a different file. Best wishes, Dagny
  3. Hi I need to export my vectorworks files so that they can be imported in Inventor. However - when I try to export to step-files, only one of the design-layers are exported, and a I have several design-layers that I would like to export at once. Does anyone know what I should do? Or is there another file-type that is suitable? Best wishes, Dagny
  4. I restarted and they went away.
  5. Thanks! They went away after I restarted Vectorworks. I have a M1 Mac.
  6. Hi I am struggling with some weird lines appearing in one of may layers in a drawing. I cannot figure out what they are, as it is not possible to select them. Have anyone seen something like this before, and know what I might do to get rid of them?
  7. I have a problem when I create a top/plan viewport on a sheet-layer. The lines disappear in the viewport and are only visible when I am zooming. That means I can only see what the drawing actually looks like when I am zooming. All other views/viewports are fine. This is only a top/plan problem. Does anyone know how I can solve this?
