Madeleine
    2
Reputation
1 Neutral
Personal Information
  • Location
    United Kingdom
  1. Is there a way to add an aluminium window sill to a window symbol? The options I can see are timber, masonary and brick only
  2. Context - Our plan drawings are split into three parts and referenced into a Site Wide Master file. Door types are created in the master and referenced into Part 1,2 and 3. All schedules are created in the master file. I am trying to make a door schedule in the site wide master file and the column where the room names should appear I am using 'Functions' and 'GetSpaceNameForObj', however this column remains blank in the report. This function works in the Part Plans but not in the site wide Master file, is there a reason for this? Separate to this, I have a 'Comments' column which I have set to 'User Field 1', I am unable to type directly into the report, however I can edit each individual door and add comments under the data tab > User Field 1 which then appear in the schedule. Is there a way to type into the user defined fields within the report? (I have ensured that the user defined fields in the data tab in the door styles is turned on to enable editing) If anyone has any suggestions on these two things it would be appreciated!
