Lorenzo S
    4
Everything posted by Lorenzo S
  1. Hello everybody, I am really willing to use the Space Tool, I tried three times in the last 10 years and always gave up due to one inconsistency or another. In 2021 I thought I'd give it another chance, but here I am again. I set up my labels and it all works smoothly on my computer. As soon as I open the same file on another computer in our network, it works with the following limitations: 1) the auto numbering does not work if the labels are placed as annotations. This might be normal, I don't put the labels in annotations but one of my colleagues prefers that. 2) an additional data field that I set up appears in the space label but is not present in the object info palette to be manually changed (yes the field appears in the space tool style and its value is set to be manual and not default). Everything is configured correctly, it works quite well on my computer, but not on the other ones in the network. Same OS, same version of VW. I attach a vwx file with two random spaces for you. In the image you see the object info palette as it shows on my Mac, on the others computer the last files (Ceiling height m) is just missing, but the filed shows in the space label and is present in the settings. All the best Space Label custom style.vwx
  2. I bump this as I am running in the same issue @Kane had. One of my colleagues uses a PC and I need to switch from AFP to SMB. The first window appears when I want to save and commit. What do I do wrong? Thanks!
  3. Hello everybody, I am working with Space Labels and in all of the fields I defined (area, perimeter, height etc.), I want all my decimal separators to be commas, not dots. All the "default" fields follow the System Preferences of my Mac (which is set to comma). I also need to use one custom field made with a Formula and that one field gives me a dot as a decimal separator, no matter what I do. I need to use a formula because my file is set to millimeters and I need the perimeter in the space label to show in meters, I guess I have no other way than using a Formula. Is there something I can write in the formula, to force VW to use a comma in that field, rather than a dot, as a decimal separator? I even tried changing the decimal separator in the system preferences to dot, relaunching VW and updating all the spaces... it then works, all the decimal separators show as dots rather than commas, it is consistent but I cannot show a dot where a comma is supposed to be. Many Thanks!
  4. Hello everybody, I am working with Space Labels and in all of the fields I defined (area, perimeter, height etc.), I want all my decimal separators to be commas, not point. All the "default" fields follow the System Preferences of my Mac (which is set to comma). I also need to use one custom field made with a Formula and that one field gives me a dot as a decimal separator, no matter what I do. I need to use the formula because my file is set to millimeters and I need the perimeter in the space label to show in meters, I guess I have no other way than using a Formula. Is there something I can write in the formula, to force VW to use a comma in that field, rather than a dot, as a decimal separator? Many Thanks!
