612 -
Everything posted by Scott C. Parker
Attaching fixture to truss causes truss to become invalid?
Scott C. Parker replied to scottmoore's topic in Braceworks
Are you able to share a file with the original and modified truss objects? Which truss are you trying to use? What lighting unit are you attaching? -
Try this, Right Click in the window and choose Reload. If that doesn't work, save, close, and reopen the file. You should be good to go. This is a known issue on our list.
My Autosave preference keeps shutting off.
Scott C. Parker replied to bc's question in Troubleshooting
A few thoughts: Is your backup folder in the cloud? Might you have a permissions issue? Could the folder be locked for one reason or another? If the backup preference hits a folder it can't write to, it might cause it to turn off the setting. -
Cable Tool for Hoists not recognizing "Motor Up" position.
Scott C. Parker replied to Nicholas Lazzaro's question in Troubleshooting
@Nicholas LazzaroThank you for your process description. I've added the need to follow the hoist when in the up position to my list of needed improvements to the cable planning and layout tools. We have another forum post in which to post power related questions and suggestions. Those of us working on the power tools tend to see those sooner than the general trouble shooting forum. https://forum.vectorworks.net/index.php?/topic/100551-power-planning/page/2/#comment-457000 Thanks, Scott -
This is also on our list of improvements. Keep these suggestions coming please. They're terrific. Thanks, Scott
Total weight of truss systems - Reports
Scott C. Parker replied to Cristiano Alves's topic in Entertainment
Well, you would need to compare the two workflows and see which one works best for you. Sam's tools allows a free preview for a set period of time. Yes, they do differ. Tools in VW are developed over different timelines depending on user needs and software capabilities. The square footage of drapes came about after user suggestions that the tool take the published weight of soft goods, as listed on various drape company websites, and calculate the total weight based on the curtain finished sizes. @C. Andrew Dunning is the foremost expert on how this works. Putting per panel weights into the LED screen tool has been suggested and is on our list of wishes for improvement. When I need to calculate LED screen weights, I often add a distributed weight using the rigging load tool after I've figured out how much my LED wall weighs from an excel worksheet. These are all great suggestions and we keep track. Keep them coming.. Best, Scott -
You can create a report for each truss system. A bit time consuming, but it's the way to go. When I was doing more show drafting, I used a third party plugin made by @Sam Jones which has a command to do this same thing. It gathers and reports weight of everything selected. Still, one truss system at a time, but wicked fast. I made a 30 second video a while back showing how it works. https://youtu.be/GD300L0gqVo -
hello Wood, We don't, yet. It's on a list, so to speak. When I was laying out rigging systems I would convert my hoists into lighting devices which gave me a lot more control for power and data. I could then insert cable lengths into a cable data field for each and put them on the paperwork. 'm working on plans (no dates to share I'm afraid) to bring cabling, power planning and control to hoists and controllers. I'd like to hear more about what you tried to include in the controllers you attempted to build. As for your putting cable info into the notes field, how do you do that now? Manually? I have a suggestion. Reach out to @Sam Jones, one of our third party developers, and ask him about how his cable tools plugin can help. Here's a screenshot I just whipped up to show you what I do using his plugin. The combination of data tags to show the notes field, in which the cable name/number is inserted, and the cable worksheet give me both the cable/hoist info and cable lengths. Best, Scott
Other gathering spots for Braceworks discussion?
Scott C. Parker replied to Brent.A's topic in Braceworks
This is the only place people will get responses from VW folks on a regular bases. The various FB groups are hit and miss. I tend to answer questions in FB groups when I can, but this VW forum was created specifically for Braceworks. -
Layer Scale question - why not just 1:1?
Scott C. Parker replied to yasin2ray's topic in General Discussion
Can you expand on this? I've not run into a limit. -
I tend to do the exact opposite. Not right, not wrong. just differ for my needs. Except for section views. Those I dimension in the viewport annotations. Basic reason for me to add dimensions to design layers (and control via classes) is to maintain what viewports see when items on stage are updated. Since I may have several viewports on various sheet layers, it saves me from having to visit all the viewports when something changes in the design layer. -
Data tag : Rigging Object Tag-Style 3 Up-Note
Scott C. Parker replied to Ben3B's topic in Entertainment
FYI, we have a new forum board devoted to Data Tags here: https://forum.vectorworks.net/index.php?/forum/186-data-tags/ You have the settings correct, but need to click on Add to Definition to insert the string. When you do, you'll notice that the settings you have are slightly different than the current setting in the Current Tag Field Definition window. You could also manually edit the top line string and change the 0 to a 2. -
Attaching swivel clamps to lighting pipes
Scott C. Parker replied to Sam Thomas's topic in Entertainment
Unfortunatly, becuase clamps do not offer ratings against the pipe itself slipping out of the clamp, Braceworks cannot offer reliable calculations. -
Personally, I always set to the thing that can't be changed by anyone for any reason, the floor. Added to that, when riggers are setting trim before the stage is in place, they'd have to do the math if I set to the stage deck. I've also shot myself in the foot playing with layer hieghts with regards to trim heights of all sorts of things. With that said, it's not hard to snap a few extra measurements in my section view paperwork to help with onsite math.
This is not working as expected for me in 2023 either. Posting a bug report about it.
@tgooch Two different workflows with different results. Given that power planning and data management are not linked at the moment, the two workflows are likely needed to produce the different sets of paperwork. I am a fan of AutoPlot and used it extensively before joining Vectorworks HQ. Though it produces paperwork and reports differently than ConnectCAD, if it fits your workflow methedology, it would be the way to go. Otherwise, CC is a solid choice. You're most welcome. Thanks for mentioning. Say hello. Great guy. I'm one who can truly say, "I knew him when..."
@Lec You can use the "report" command to create worksheets as you need. The cable tool itself is not freindly to DMX or data yet. However, your reports will pull any/all info from the lighting units. It'll also pull info from the cables, distros, etc.
Unfortunately, these two functionalities were accidentally omitted from the latest release. They are on the list to be added back. for the time being, you have the option to configure the cables themselves (after the breakout) via the configure cable button in the OIP.
If you want a non-braceworks worksheet with all the items on the system in question, @Sam Jones has a tool to gather all items and add them to a worksheet with weights.
So, let me understand. You're looking for accuracy of 1/8"=1' down to the difference of an unsharpened pencil? Kidding aside, I just printed these on my HP Laser Jet Pro M477 and they are both spot on. Directly from VW. Top in a viewport and the bottom printed directly from the design layer. I also checked via exporting to a PDF and printing. Same result. All are spot on.
If Tom's suggestions work, let us know. Otherwise, we do know of an issue with M1 and the driver for these dongles. The dongle manufacturer is working on fixing the driver.
My numbers are off to the side of my light
Scott C. Parker replied to Asincliar's question in Troubleshooting
You're missing step is to edit the 2d layout in the Label Legend to actually place the numbers where you want them. See attached and let us know if this fixes the issue.
