Scott C. Parker
Vectorworks, Inc Employee
    1,055
Posts posted by Scott C. Parker
  1. Usually, making connections on the input automatically connects to the output. But sometimes, one input is not actually the same as the connected output, most often when circuit breakers or fuses are involved.
    Add this to your workspace to check internal connections.
    • Like 1
  2. 25 minutes ago, William McLachlan said:
    4) when using equipment summary keys, is there a difference in their operation if they're placed on a design layer vs. directly on a sheet layer?
    5) Same question for Graphic legends - are they any more or less capable or used differently if they're placed on a design layer or sheet layer?
    4. They're supposed to work the same for both design and sheet layers.  Personally, I always recommend placing them on design layers and using viewports to place them on sheet layers. It gives more control over the resulting display, specifically the scale. I've often reduced the scale by 10-20% without confusing the crew.
    5. Graphic legends do not work in design layers.
    • Like 1
  3. There's something about the pass-through circuit in the Coffret Tri 20Kw. I don't know what, but to get you the calculation you need for the system, if you bypass the Armoire 2 and go from the Source 2 to the Armoire 3, you'll get the calculations to work.
    Drawing the cable connections in the schematic view correctly, @JCodgell is correct; there's a known issue. However, if you want to draw lines, instead of connecting the two distributors using the cable tool, you can use the Connect Selected command in the schematic view, shown here.
    BTW, the Coffret Tri 8 lacks connections to circuits 7 & 8 N & PE
  4. 2 hours ago, Cristiano Alves said:
    With a blank new file, it happens the same .
    I don't know if you have tried these troubleshooting steps, but... Close VW and try number one first. If that doesn't work, try #2.
    1. Please reset your Resource Manager Cache to force a fresh download of the VW libraries.
      1. Refreshing your Resource Manager will update your library to the latest published symbols. You may need to clear your local RM cache file. Refreshing the RM doesn't always do this. Delete the RM Cache folder and then refresh the RM and it'll pull down a complete set of updated RM files.
        Win: C:\Users\username\AppData\Roaming\Nemetschek\Vectorworks RMCache\rm202x
        Mac: /Users/username/Library/Application Support/Vectorworks RMCache/rm202x
        Remember to replace the “username” with your computer username if you copy and paste the file paths
        Your file location might differ.
    2. Reset your user folder.
      1. Find your user folder for 2025 and rename it to something like 2025Cristiano so you can restore it later
      2. Start VW, and a new user folder will be placed. You might need your serial number for this.
    If resetting your user folder works, you can then start adding custom settings and plug-ins back in. When I'm searching for an item that creates conflicts in my user folder, I add each custom plugin, one at a time.
  5. 19 minutes ago, LiteDoctor said:
    Well, that's a lot to go through but it does work. A couple of questions:
    I agree!
    I've not explored my workaround enough to answer your questions with clarity right now, and I'm neck deep in some other things.
    I still prefer the line offsets Autoplot offers, and I hope to offer the same in VW's version as soon as practical. aka, not soon, but it's on the list.
    As for naming symbols, you can save the symbols with a new name for each, but use the short name field for paperwork. I never use the symbol name on paperwork, as it's always too long for the column width in my reports.
    • Like 1
  6. @JamesB1 I played more. I renamed a few connection components to help me trace where things were getting connected. You'll see what I did in this file. I spent my time working on getting one connection working as expected, and it calcs the three phases. Giving each component a logical name helps trace how things should be connected. I think all the work I did was inside the T4 symbol.
    hth, Scott
    PowerTest SCP.vwx
    • Like 1
  7. On 6/16/2025 at 5:11 AM, jcogdell said:
    The workflow is that you need to draw you power cables first, then draw the data cables.
    The adapter notification dialogue will probably be triggered, select the option to not insert adapters and close.
    On 6/14/2025 at 9:31 AM, Marco Erbert said:
    What is Vectorworks’ approach when you have 200–300 fixtures in a large rig? Somehow, you also have to calculate the amount of data cabling, not just the power cables.
    All this got me thinking, and I have a workaround while data is being further developed. One issue is lighting content. VW automatically adds the power consumer parts to each light, and this doesn't help us with data connections. To fully use the cable tools for both power and data, we need to add new power components to our gear. After doing so, we can build a full set of paperwork and schematic layouts for both power and data cable runs. I've made a video and attached my test tile.
    image.png  DMX cabling demo w data input w components v2025.vwx
    • Like 1
    • Love 1
    I would be very happy if we could get a working tool for data cables again with SP6.
    Hello Marco,
    I encourage you to add the legacy version of the data cable tool to your workspace and use it for now. Data is being worked on, but it's not going to make it into SP6, nor into 2026. With all the other items that need data, we're working on improving the underlying coding so it works properly across the board vs. just fixing what's missing for lighting.
    If you want even more powerful data cable functions, check out our third-party partner's cable tools at autoplotvw.com. Sam's tools were the basis of our old set of tools, and he continues to improve them. They're fantastic, though they don't do 3D, power calculations, or Braceworks.
    • Like 1
  9. On 6/5/2025 at 5:20 PM, hdmcclx said:
    by default all Cable Parts and Distributor Objects get assigned to Lighting, is there a way to change these
    Not yet. The power/cable tools were built for lighting first, as the lighting system is the most developed in VW. As we push improvements to other tools, the power/cable functionality is being worked on. Separating out power/cables for audio is on the list, as is power/cable for hoists, video, LED, etc.
    For now, you can filter some of your needs by layer. Even though it'll still list as lighting power, you can limit your audio if it's in an audio layer.
    • Sad 1
  10. 12 hours ago, hdmcclx said:
    3D input object
    Do you mean the red box added to show the rear of many movers? It's really just added geometry to show a direction and doesn't have functionality to grab onto. The power connectivity for lighting units is coded rather than being an added consumer component.
    And for distributors the logical spot would be the corresponding Input/Output connector
    I agree. It would require more processing power and affect performance. At the moment, we're just counting how many connector components are inside the symbol and matching connections. Adding location clicking would require each cable to find its corresponding start/end points, one at a time, to be drawn properly.
    What would be easier and keep performance up would be to add a default slack distance for a device.
    On 5/29/2025 at 3:20 AM, hdmcclx said:
    Another example, i built a custom 96-way touring rack Distributor with a heap of Socapex outputs, The top row of which is over 1.5m off the ground (The insertion point being at 0 Z Height)
    If we added a default slack distance field, you could add 1.5m, and all cables connecting to your distro would automatically add slack to all cables run to it.
    Thoughts on this?
    • Like 2
  11. On 5/22/2025 at 12:58 AM, MTH said:
    I gave it another go and made sure to do all the tricks you said still having the same problem.
    Please post a sample file so that the collective can take a look.
