I've just installed InteriorCad... but can't find it anywhere within Vectorworks. Is there somewhere I need to click or open?
From memory, a few years ago I installed it on another computer and it just appeared that time on the top "File", View" bar, beside "Window",
Thanks.
Hi,
I have a rectangle at the start of the line measuring 400mm. I want to array it along that line, around the arc of 628mm and then along the line of 1422mm. How do I go about this?
I've tried using "Edit", "Array along a path", etc... but it's not quite working or I am doing something wrong with it.
All suggestions welcome.
Thanks.
Hello,
I have my keypad views. Front, sides, back, top, 45 degree looking down... but is there a way of view from 45 degrees but level, just like a front/side/back view?
Thanks.
Interesting, I'll have a wee look a "Editor" then, thanks.
Colombo impression... "One last thing."
Is there a way to assign the top row of numbers (1-9) on a keyboard to an external keypad or even to a keyboard keypad? Their functions are different, eg... If I press 2 on the upper row I get "Line" and if I press 2 on external keypad I get a view.
Thanks... noob here.
I wonder if there's a way to change the font size on the text within the "Navigation-Classes", (The Classes Labels)?
Or even a way to edit it? e.g. Inserting line breaks? etc... I know you can set up sub-classes. I'm talking more a visual eye thing. Much the way you can add colors and lines to Excel.
I think I will start with this idea first and try it for a while, then try some others.
One question though... How do you name/label Classes so that they would always appear at the top of the two drop down windows, ie... The "Navigation-Classes" window and the "Object Info-Shape" window? I want this so I can avoid always having to scroll down to find them in different places each time. Some of the drawings I work on have a list of classes as long as your arm so having them always appearing at the top is preferable.
I'm thinking labeling them with the number 0 at the beginning?
Thanks, that's great.
Is there a way to save my new Dim Standard to all furture drawings? I only ask because I opened a new document and my new "Dim Std" was not available. I would like for it to be always available going forward.
Hello,
when I dimension something the actual numbers appear above the line. For tidiness/presentation I drag each box down on to the line. Is there a way to preset this up so that the box/numbers are always on the box?
Also are there ways to preset dimension preferences. eg... The leader lines are removed, decimal places, etc...
Thanks.
Hello,
when I draw a rectangle and it turns white, to show it's enclosed. For me it's a different colour. I change it back in attuites but it doesn't stay like the the next day, or in a new drawing.
Does anyone know what I've pressed or selected?
Thanks.
Hi,
When I make a new class, is there a way to save it so that when I reopen the drawing, at a later date, that class is there for me? At the moment it's not there after opening it again.
Yes that is the box, but now when I double click to bring this up for cropping or Annotating, its a different smaller box that appears, with no options to select on it. It just informs me.
Anyway, I will be at work soon and can try what you suggest. I can also post fully what the popup window says if what you suggest doesn't do the trick.
Thanks.
