HI all,
We have an EPS file that we need to convert and edit so a CNC machine and jet cutter can print it (and I need to add some holes for bolts etc..)
I have done this process before about a year ago and had succes, however, I can't seem to do it currently, I might miss a simple step that I forgot over time but it starts doing my head in and couldn't find the solution in the forum.. been playing with it for about 2 hours now and can't really afford loosing more time on it so I hope that someone can point me in the right direction...
If I import the EPS file and use "Command K" it does not explode (sorry if explode isn't the correct wording..) also ungrouping doesn't seem to help.
If I double click on the file it opens the "bitmap crop edit" but can't do much there...
I also tried to export it as PDF and then import the PDF with ungrouping, it does give me something but definitely not the result I am after...
The EPS file is a line file (not a bitmap) but for some reason I can't figure it out.
Any help would be greatly appreciated.
bellow 2 screenshots of what we did last year...
This was the eps import:
And then I was able to get to this 2d image which is what I need.
Our current design is bellow but I can't even remove the measurement labels...
Thanks everyone
ps working in VW / brace works 22.
