Thunder
    7
    Never
Everything posted by Thunder
  1. quote: Originally posted by Thunder: I am looking for an Animator Program! I want one that is Mac compatible and easy to use with VW 8.5.2 and if at all possible not too expensive. But overall the bottom line is something highly recommended by Vector Works that does not require a complicated export/import procedure. All informaton is appreciated!! Thanks From what I have gathered from the VW program it is some what limited in the fact that other then the camera you cannot have any other moving parts such as a tool performing a task or a door opening in front of the camera as it moves through the house. Specifically we want a progam that would let us animate our repair procedures, Example: A panel moving away from the unit A tool performing a task, the part being removed, the replacement part being put into place, the unit bieng reassembled. Ultimately we would also use it to animate or production procedures.
  2. I am looking for an Animator Program! I want one that is Mac compatible and easy to use with VW 8.5.2 and if at all possible not too expensive. But overall the bottom line is something highly recommended by Vector Works that does not require a complicated export/import procedure. All informaton is appreciated!! Thanks
  3. Can anyone tell me where I can get a list of error messages for VW 8.5.2??
  4. Can anyone recommend a good circuit board design program possibly one that will work with VW. Preferrably one that has an autorouter. Any suggestions would be helpful.
  5. I HAVE AND PART WITH MULTIPLY SWEEPS, IT AS BEEN IN THIS PARTICULAR FILE FOR MONTHS. EACH SWEEP HAS A SUBTRACTION, WHEN THE PART IS TRANSFERED TO A DIFFERENT LAYER WITH A DIFFERENT SCALE THE OBJECTS ARE DISTORTED AND I GET A MESSAGE SAYING THE SUBTRACTIONS ARE ILLEGAL. WHAT IS CAUSING THIS PROBLEM??
  6. I am trying to print multiple saved sheets with out having to select each sheet seperatly. Basically I want to be able to hightlight a file icon hit command+p(print) and have all sheets be printed without having to open the file and select each sheet individually for printing. Can this be done?
