dlopez-gutierrez
Vectorworks, Inc Employee-
27 -
Reputation
12 GoodPersonal Information
Location
United States
Recent Profile Visitors
Hi Bart Thanks for reporting the issue I just confirmed the IPR bug with the IES light inside the symbol, I will work on this bug I was also able to reproduce the problem with the inverted exposure in VW 2024 and confirming that the bus was fixed for VW 2025,
- 1 reply
- 3
Redshift - how to make metallic textures ?
dlopez-gutierrez replied to Gaëtan R.'s topic in General Discussion
I change the render style to redshift exterior final to make a fair comparison between RS and Final Quality Renderworks, This is the rendering if I change to native RS material, with exactly the same parameters from the Edit Metallic Shader Dialog, can this be consider better? -
VW 2023 SP4 crashe son return to the VW screen
dlopez-gutierrez replied to MWAT's question in Troubleshooting
Thanks for reporting the bug problem. I was able to reproduce the crash with VW SP4. This crash is related to a bug that was reported to us previously. We already have a fix for this problem and we plan to release the fix for this bug in SP5. sorry for all the inconveniences, David 660076813_2023-03-2212-09-08.mp4 -
I got the zip file, let me take a look and Ill update when I get relevant info. -
Hi @MWAT This bug is new to us, is it possible to get a private message with the model so I can take a look and debug it locally? I will work on this issue. Thanks -
Transparency reversed in Shaded vs. Renderworks?
dlopez-gutierrez replied to SamIWas's topic in Rendering
I check the Material "Metal Perforated Plate 01 RT" and looks like the rendering will be correct for this file [VB-192415] Shaded inverts image-based transparency shader - Vectorworks JIRA -
Hi @SamIWas We are currently working with that problem, if you post the image file or a VW file with the material, I can test to make sure it will be fix in future releases. thanks -
Datasmith Export Crashes Vectorworks
dlopez-gutierrez replied to Steve Kennedy's question in Troubleshooting
Hi Steve Can you please share the file causing the problem so we can reproduce locally and find the root cause. Thanks -
Thanks for reporting this problem We are expecting the fix to be included in VW 2023 SP3.
Hi Simon The parent actors are the way we represent the objects in the scene. Due to the plugin restrictions the object's geometry can only be stored in leaf nodes. so we need to keep two nodes one with the metadata and a child node with the tessellation. We discuss the possibility to merge those two nodes, this will keep the geometry and data together. However, this is a large change that cannot be part of SP4, so we are considering 2023 as the potential target.
Use the Datasmith Direct Link preferences to enable saving metadata. then in unreal select the top actor in the branch,
let me check and Ill submit the video with the steps. In settings there is a new checkbox to enable/disable saving the metadata and records file. default is disabled. But let me double check that the data is extracted correctly
Hi Simon Currently Twinmotion is not using/showing the metadata info that we save. We tested the correctness of the metadata by loading the models in Unreal, The way to retrieve the metadata is by loading the udatasmith file. in the scene graph instead of selecting the leaf nodes select the first node in the branch. In the user data you can locate the metadata In addition if you open the Datasmith file using notepad you can find in the last section the metadata extracted from the objects. Hope this help
After doing some research I find out the problem started when users first use the menu item to export the model, then try to connect to Twinmotion using direct link. A temporal solution consist in loading the model and using only the toolbar icons. The permanent fix will be available in SP3
