Hi All,
I've been a VW user for many years, but have mostly used it for theatrical lighting plots. In the last year I've started doing some sculptural work and am using VW to iterate on different ideas.
I'm running into an issue currently. I'm trying to model something that, admittedly, is a rather complex geometric shape for VW to model. Essentially, I'm trying to make a tube out of a bunch of "rebar" that is twisted together and then take that tube and bend it over into an arch. My method so far is to use the helix tool and a circle and extruding along path, then mirroring that extrude, adding the two solids, duplicating, rotating the duplicate in plan, using add solids to combine, rinse and repeat until I have a cylinder. Next step would be to use the deform tool to bend this over into an arch. The resulting generic solid has a ton of surfaces vertices and empty space, so I'm not exactly surprised that VW becomes unresponsive when I try to use the deform tool. However, I'm not sure where VW's limit is for a function and it would be great if there were a way to vet an action before performing it and then having to force quit VW because it dutifully starts to try to calculate the impossible.
So, two questions here. First, is there a way to have VW warn me or for me to check BEFORE VW starts a ten minute long calculation that will ultimately fail? Second, does anyone have a recommendation for a process to do this idea that WON'T break VW?
