9,482 -
Everything posted by Christiaan
Viewports coming in at strange scale from DWG
Christiaan replied to Christiaan's question in Troubleshooting
Seems to me the only option I've got is to manually scale everything on each Sheet Layer. Fortunately they're all incorrect by the same proportion (3.72%), so I can just select everything on each Sheet and scale by 0.9628 -
No, I don't think so. I checked the notes and there's no mention of railing tool changes in Update 2.
I'm importing DWG drawings and I've verified that the information on the design layers is the correct size, so I have the units correct (mm), but the Sheet Layer Viewports are at a weird scale and don't fit correctly within the Sheet border. For instance I end up with a Viewport which should be at 1:100 coming in as 1:96.280 instead. Have a feeling I've come across this in the past but can't remember how I resolved it. It's quite a few files, with other objects on the Sheets involved, so I don't want to correct them manually if I can help it.
DWG Import - Set all attributes by class
Christiaan replied to Ross McLee's question in Wishlist - Feature and Content Requests
In order to get the popup to appear you may need to check, uncheck then check again, if some but not all of the Classes are already set to Use at Creation.- 4 replies
- 1
- dwg import
- attributes
(and 2 more)
Tagged with:
We need some more info. Can you post some screenshots or a screen-recording demonstrating the problem? And/or the file?
Tried the gravity mode?
Brilliant, thanks Juan, I knew you'd get there eventually. I'll check all your changes later today.
Can I make this hatch repeat perfectly?
Christiaan replied to line-weight's question in Troubleshooting
Same here 😆 -
Notes Manager / General Notes / Callouts Suggestions
Christiaan replied to _James's question in Wishlist - Feature and Content Requests
Okay, thanks Tom. I'll see if we can get that extended or some other solution. In the mean time I can edit it for you @_James -
Plasterboard offset at window reveal with Wall Closures
Yes it's native Window object (with a separate hybrid object for the external and internal sills) -
Christiaan posted a question in Troubleshooting
I think I'm right in saying that we can't do something like this with Wall Closures? We can only do one of these: -
AI integrated Rendering
Christiaan replied to twk's question in Wishlist - Feature and Content Requests
Nothing on the trilobites, which reigned for 300 million years, twice that of the dinosaurs. -
I'd also like this behaviour when copying and pasting Callouts across layers: -
I'd like an option when copying and pasting a Callout for the first time in a file for a pop-up to ask: Would you like this Callout to: A. Remain associated with the Keynote it's currently associated to. B. Associate to a Keynote on the layer being pasted to or generate a new Keynote if none currently exists. [with a choice of existng Keynotes available on the current layer] Remember my choice in this file. If the user chooses option B and 'remember my choice', from that point onwards: Callouts will automatically be associated with a Keynote on the layer being pasted to if there is just one Keynote object. If there are multiple Keynotes on the layer being pasted to a popup would appear asking the user which Keynote they want the Callouts to be associated to. When copying and pasting a Callout on the same layer (i.e. without moving it to a separate layer) it would simply stay associated with its current Keynote. I almost never use workflow A, which is the current default behaviour. The only question is should this behaviour also be triggered when using the OIP to move Callouts from one layer to another. I think not in this case. They should just remain associated with their current Keynote by default. I wouldn't want popups appearing when moving objects between layers using the OIP. And I when I do keep Callouts and Keynotes on different layers the OIP is probably what I'd use. What do you think?
@_James can you remove number 4 from your list? We use Note Descriptions as described here https://forum.vectorworks.net/index.php?/topic/99252-notes-manager-general-notes-callouts-suggestions/#comment-458702 -
Hi Mikieluca, welcome to the forum. Can you provide more details? What's the name of the resource you used? I presume it's a Renderworks Texture.
We don't need AI for that. The construction industry is responsible for nearly 40% of CO₂ emissions historically. -
Duplicated contour line labels are a problem
Christiaan replied to Jeff Prince's topic in Site Design
can you upload a new example file? This one is missing for some reason. -
Advice on modelling V-shaped structural supports with tapered legs
Christiaan replied to ryanesson's topic in Workflows
That's great, love it 👏 I'm all good thanks 👍 -
Another skylight insertion question
Christiaan replied to hollister design Studio's question in Troubleshooting
Great! -
Definitely due for modernisation. Roof lights are the only thing I didn't bother modelling on a recent project. Can't see them on the roadmap but maybe once this is sorted we'll see some movement on this: https://www.vectorworks.net/en-US/public-roadmap?url=roofslab-modernization
