Niccinator
    4
Everything posted by Niccinator
  1. Hi, In the Repetitive Unit Object Properties Window, could you please nest the contents of the "Chose Symbol" window, where the symbol is shown/picked, please? This way I can easily see which repeating symbol is active without having to go one layer deeper. I use the Rep Unit tool a lot and with a lot of different symbols. Not needing to click into the "Chose Symbol" Button would save me a lot of time. Thanks, Nic
  2. Hi, When I go to change the visibilities of a viewport I often need to change (and or check) both layers and classes. Could you incorporate a button that could swap between layer visibilities and class visibilities in the Viewport (layer or class) Propories window, please? Like how when editing a hybrid symbol you can easily change between 2D and 3D on the right click menu. Thanks, Nic
  3. Hi All, I'm looking for the best way to add numeric values (quantities) from a Record format field value. I have a "garbage station" symbol which depicts several garbage cans. The attached record format has fields for "Compost", Recycling" and "Garbage" and would like to specify the number of bins in that particular symbol for each type. I then need to put it into a report, where the bin type is in column A, and the total number of bins is Summed in Column B from all symbols placed. Right now I can only get it to work with each bin field getting it's own column, so essentially I need to swap the rows and columns, or find a better way to Any help would be appreciated! Thanks, Nic
