Hi-
I'm relatively new to VW, having been using it for about a year. I'm more familiar with AutoCAD and I'm looking to replicate a feature which I used to take advantage of a lot.
In AutoCAD, if you put the lines within a block on the 0 (zero) layer, those lines will take on the display properties of whatever layer the block is inserted on. Lines on the zero layer are like plain vanilla - ready to be flavored by anything. In Vectorworks however, objects always retain the properties of the Class they are drawn in.
In my workflow this has made things quite difficult - hunting down symbols and groups that sometimes end up in Classes they shouldn't be on is difficult, and implementing viewport overrides is much more difficult, since VW gives VISIBILITY priority to the highest element - the group or the symbol, but gives DISPLAY priority to the lowest - the Class the objects are on originally.
If I could only put things in a Class where the lines change appearance depending on what Class their group or symbol is inserted on things would be much easier. Is there any way to do this?
Would posting an example help?
Thanks
Chris
