I am having some issues getting the Custom Tool/Attribute tool working for walls in VW12. Previously it seemed that you could create a script that would allow for wall properties including class and width set by creating a custom tool for each particular wall setting. I have tried numerous ways to set this in VW12 using the custom tool/attribute tool and have now gotten the width of the wall to work for each wall type but cannot get the walls to default too different classes.
The script created and modified is as follows
Procedure CustTool;
VAR
Result:BOOLEAN;
BEGIN
PushAttrs;
ClearCavities;
DoubLines(6");
PenSize(20);
PenPat(2);
SetZVals(0", 0");
PenFore(255);
PenBack(0);
PenPat(2);
FillFore(66);
FillBack(48);
FillPat(1);
PenSize(20);
PenPat(2);
Marker(0, 0.125000, 15);
SetWallWidth(6");
NameClass('Wall-Ext-Frame');
CallTool(-208);
PopAttrs;
END;
Run(CustTool);
What do we need to do to change this so that the class will default with a change in tools(classes change)
OK now this is weird, I have just created another tool using the all custom tool attributes for another wall. Once again nothing really worked correctly however, now the above one does. What gives?
Thanks
Cam
