JGoss
24 -
Everything posted by JGoss
Yes, I was referring to Cast Lighting's WYSIWYG program. It appears from their documentation that when exporting a DXF/DWG file the text fields will export as text fields, but they're not showing up that way in Vectorworks. Does anybody have any experience with this? Thanks!
Has anybody had consistent success importing DXF or DWG drawings that have been exported from WYSIWYG? I've receieved a couple files that have been exported as DXF's and all of the instruments, text blocks, etc are drawn as individual lines. I'd like to be able to get all of the lighting symbols to at least come in as symbols/blocks, with the text as editable text fields. (Obviously it would be great if Vectorworks could import the drawing and have Spotlight recognize all of the WYSIWYG data) Anybody have any suggestions? Thanks,
Problems with Printing Symbols in VW10.5 to PDF for OSX
JGoss replied to luminouslx's topic in Entertainment
I had problems using the grey text labels, our HP 750c+ plotter didn't make them clear, especially when a fixture was rotated off 0?/90?/180? Thats why I prefer to use the graphical ellipsoidal fixtures for that very reason. When you have 300+ fixture on a plot, all that grey text blends in, but the slashes always stand out. Just my personal preference... -
Nope, you're not doing anything wrong. That's just how it does it. Annoying huh? It would be nice if that got fixed one day... I use the Lightwright import/export functions to get the proper information updated into the plot. It's much faster then editing every unit.
I'm wondering if anybody knows why the following happens: When using an instrument symbol that references another symbol without any change from the original; for example the graphical Source 4 fixtures that come with Spotlight, and you insert the Etc Source 4 36? symbol (that is just the Etc Source 4 body masquerading as a 36?), the Obj Info palette shows no data. It is kind enough to tell you that it actually inserted the Etc Source 4 body symbol, instead of the Etc Source 4 36? that you actually wanted in the drawing. Now you can get around this issue by adding some graphical element to the 36? symbol. It doesn't even have to be visible. As long as there is some difference, it will insert the proper symbol and drop in the correct Light Info record information. I'm using the Etc Source 4 36? symbol as an example because it comes broken straight out of the box. Any symbol based on the same idea will also do this... But why? And more importantly, can it be fixed? Or should I say, will it be fixed?
When I use just an arrow and drop it onto the PAR symbol, I usually have to play with the arrowhead and line settings to make it look right. Try making the line longer and the arrowhead smaller. Once I have what I want, I turn it into a symbol so I can drop and rotate it however it needs to be.
Miguel- As the ALD down at Florida Grand Opera in Miami, I deal with the same sort of headaches that you mention. FGO has both Autocad 2005 and Vectorworks Spotlight 11.5. Except for the designers that still use pencil and paper, most of our designers work in Vectorworks, but one or two work in AutoCad. Like Steve B. mentioned, I have found that almost all lighting designers (especially the ones working out of NYC) use Vectorworks. Though sometimes the translations between AutoCad and Vectorworks can be tiresome, I have developed a pretty good workflow with the Technical Direction department, which uses Autocad. Try importing the CAD drawings into VW using different settings. Sometimes I find that I need to play with different import options just to make everything work right. Also, I find that just because a designer uses Vectorworks, they don't always use the Spotlight features 'properly.' I often have to go thru and clean up the plot so that I can transfer data smoothly between Lightwright and Vectorworks. When you update your venue drawings you can do them in either AutoCad or Vectorworks, as long as you pay attention to how each file type exports to the other. In the end, you'll probably find a need for both Autocad and Vectorworks. They both will draft a light plot, but they go about it in different ways. Contact me if you have any other questions. (jgoss@fgo.org)
I generally just drop a symbol on top of each PAR, often attaching them as an accessory so that they stay with the PAR. However this can create a problem when moving data between LW and VW. The other solution that I have tried with some success is using Unicode characters. It can take a little bit of work to set it up, but it allows you to use the field of your choice, and you can treat it like any other label legend field. Here's what I did: Go to Microsoft Word and in any document, go to the Insert Symbol menu command. This will bring up a symbol dialogue box. I use 'Monotype Sorts' characters 214 and 215, also known as Unicode characters 61654 and 61655. This gives you a up/down and a left/right arrow. (If you want a diagonal arrow, there are some other choices) Once you find a character you like, go ahead and insert it into the Word document. Then copy this symbol from Word into a text block in Vectorworks. You will then need to put your label legend field of choice (I use User Field 1) into the label legend you use for your PAR cans. Then edit your label legend, place the field where you want it on your lighting symbol, and change the font to be Monotype Sorts (or whatever font will correctly display your arrows). After exiting you will need to copy the appropriate arrow into the field for each PAR can on the Object Info palette. (Or you can set up a keyboard shortcut to make it quicker) It will display as something different on the palette, but should display correctly on your PAR can. There are other ways of achieving the same end result (like creating separate PAR symbols for each lamp axis, or creating different label legends with an added graphical element for each lamp axis variation), but this puts the arrow in the label legend and doesn't clutter your file with lots of unnecessary symbols. hope this helps
I also am able to use VW 11.5 Help in Safari 1.3. Next time you try wait a little bit - sometimes it takes ~30 sec for the Java to load and VW Help files to display. Because the help file uses Java, make sure you are running the current version. (Software Update should take care of that) One other thing to try is to go the VW Help folder (Applications/Vectorworks 11.5/VWHelp) and make sure the webpages located there opened into Safari, instead of IE.
Have you tried opening the .txt file in Excel or any other spreadsheet application? I often open the files in Excel just to make sure all of the data coming out of Lightwright or Vectorworks is the data that I want to be moving - and is correct.
From my experience with workgroup references the origin of referenced drawing will match with the origin of your open drawing. I haven't found a way of telling the referenced drawing to center on a particular spot that is not the origin. Hope that helps...
Here are 2 things to try: Delete your preference file. It's located in user/library/preferences/ You'll have to re-enter the serial numbers, and reset any other preferences you have... The other more drastic option is to delete your existing installation and re-install. Most times this will fix it. These may not be the best options in your particular scenario, keep poking around these Tech Boards, maybe you'll come across a simpler 'duh!' solution
Though the Source 4 Revolution does not show up in the Vectorworks Resource Browser, you can find the Revolution in the Field Template Soft Symbols. Check out FieldTemplate.com.
Kevin- Does this known bug only affect accessories, or does it affect other instruments in a file that has accessories? I've had problems when importing/exporting information to & from LW4 where the Spotlight ID's get mixed up and no longer correlate to the proper instruments. Which obviously makes transfering the information difficult.
quote: Originally posted by michaelk: I'd also like to know if you can choose which instrument symbol is used in the Active Label Legend. Sometimes is chooses a reasonable fixture, but sometimes it chooses the symbol for a practical or an inkie. If you set the label legend that you want to be active in the label legend manager (by selecting the label legend, then clicking "Set As Active," this label legend will show up in the Key to Instrumentation. I've noticed there is some pattern to how the instruments are sorted in the Key, and after playing with a new blank plot, I've discovered that you can drop your lighting instruments onto the plot in the order in which you want them to appear in the Key to Instrumentation. This also works for accessories. Though this is a silly way to go about doing things, one could 'cheat' the system by creating a template that had all of your symbols already dropped in your plot in the order that you wanted. When you were ready to insert your Key, you could just delete those original symbols, and the ones that were still on the plot would be sorted and counted properly. I'll have to see if this actually works....I'll post back if it doesn't. (Obviously any lighting symbols that aren't in the plot won't go onto the key) For future updates, a lighting symbol sorting maintenance feature would be nice. [ 01-22-2005, 04:21 PM: Message edited by: JGoss ]
Has anybody found a way to sort lighting instruments before dropping the key onto the drawing? I know I could manually go into the group after its placed in the drawing and rearrange everything - but that takes too long. And then I just have to go back & do it again if I need to add or change something on the plot. Please don't tell me that I have to wait until VW 12 - I know there's got to be backdoor trick... Thanks,
Has anybody else had any crashes when moving symbols or creating symbol folders in the Resource Browser? The first crash was when I created a symbol folder. Then, after opening the file again, I was able to create the folder, but it crashed out after moving a symbol into the folder. I'm working on cleaning up someone else's plot, and it has a lot of unused symbols (probably 200+). Could this be part of the issue? Any guesses if this could be a potential bug or maybe an isolated file issue? Thanks, Jon
The simplest way that I know to rotate a bunch of lighting instruments without changing their relative positions is to change the rotation in the Object Info palette. Using this method, one could take a group of instruments that currently point US, type 180? into the rotation field, and they would all point DS. This is also very helpful if you were sloppy about dropping them with their proper rotations and you want them to all point in the same direction.
Thanks for the info Kevin - that's something I've also been trying to fix. Will the 'find/modify & delete key then enter key sequence' work for updating other fields to the (new) default that has been modified? I suppose if Nemetcheck NA published all of the info and tricks for Spotlight it would put you out of a job? Thanks for your help
I have imported drawings from a co-worker using AutoCAD 2004 into VW Spotlight 11. Everything appears to be working fine, the drawing spaces import into the VW Viewports/Sheets just fine.
I am using VW 11 Spotlight (w/ RenderWorks) on a 15" Powerbook 1.25 GHz G4 w/ 768 MB RAM (OS 10.3.4) and have no problems. Though the rendering is not immediate on complex drawings, it is definitely speedy. And blows the comparable PC's at work out of the water. I find that the 15" provides plenty of drawing space for the most amount of portability-and my Powerbook is always with me. And if when you need more screen room, you can easily hook it up to that big external display.
Justin- The Autosave function works very nicely. I use it all the time, and it has saved me a couple times. If you want VectorWorks to save a backup copy, choose the "Save To Separate File in Backup Folder" option in the Vectorworks Preferences, which creates a duplicate file of the same name in a 'VW Backup' folder in the same location as the original file. Perhaps there is a way of changing this default location and file name, but I'm not sure how. If you want VectorWorks to automatically save your file every 5 minutes (or whichever interval you desire), deselect the "Confirm Before Save" option. It will work in the background and automatically save it. I prefer to deselect the "Confirm Before Save" and select "Save To Separate File in Backup Folder," thus automatically saving a backup copy every 15 minutes. This does not save your open and active file. When you use the save command in the file menu you are saving your open & active file. I do not believe that the Autosave file is actually opened at anytime during the Autosave process. VectorWorks is probably just scripting a 'Save a copy as' command. (but I'm not a programmer--just a guess) Since the backup copy is saved (in the VW Backup folder) to the same folder/location, if that location were to go offline, VectorWorks would likely notify you, since that's also where your open file is located. Or, it just might crash out. Haven't played that game, just a guess. I have also found that when working on a slow or buggy machine choosing to Autosave after a determined amount of operations is nice, that way if the computer craps out, I can usually recreate a number of steps instead of 10-15 minutes worth of work. Hope that helps
I have tried using the prepackaged LW4 automated actions and Spotlight import/export mappings that came included in the Extras folder of Spotlight 11. So after exchanging data back and forth on a project, here are my questions/concerns: How could one determine the label legend used per instrument? The automated way makes it so that the label legend info gets dropped into the "Instrument Type Other CAD" field, which appears to make it a global choice for all 6x12's (for example). Obviously, I don't want all of my 6x12's to have the same label legend, but it should be determined on a unit by unit basis. When transferring striplights information back and forth between LW4 and VW, I don't want my LW paperwork to say Cyc Left, Cyc Ctr, Cyc Right for the Instrument Type. So if i fix that, so it all says Cyc, it also changes my symbol name so that when I export my LW information back to VW, my cyc units all change to that one type, which makes the drafting incorrect. Has anybody found a way to take LW information and plug it into a VW Spotlight drawing? Often times I have plots and LW data sent to me that were created separately, and I would like to figure out a way to streamline the data (without sitting in Excel and manually entering/merging ID's for 300+ instruments) I'm sure there's a work around for these items. Perhaps it means scrapping the prepackaged fixes and creating my own. If anybody has any ideas of things that have worked for them, please let me know. Thanks,
I have been using VW SL 11 for a couple weeks now, and none of your suggestions/bugs have been fixed/implemented. The viewport functionality is really awesome and seems to be worth the upgrade, but I have yet to play with it extensively. -JGoss
