michaelohhh
    8
    Never
Everything posted by michaelohhh
  1. I am using Win2k SP3 and logged as admin. But seems neither here nor there as problems appears to be self-resolved. yesterday i opened QT 6 to check version, and after that, no probs with batch render names, either as admin or power user. Nostradamus said it would happen like this.
  2. Shirley, ok....don't know why, but when i started up QT 6 to check the version, suddenly VW will accept batch render filenames. perhaps everyone sharing this problem should give this a try? neglected to mention here that i am running an Win/AMD machine.
  3. Shirley, parameters of the filename problem: logged on as administrator using OpenGL low with nurbs off using QT6.3 no file's in the batch render file. destination folder is one created by administrator(me). hope this helps.
  4. hello anais, i am suffering from the exact same problem. have you found a solution/work-around? any clue as to why you've received no answer to this mutually impt. query? help us, we're in here!
  5. Shirley, i logged on as administrator and i still have the problem of filename creation. Tried different filenames etc., to no avail. i really would like to figure this out, as i now have three seperate projects to render, some 50 sheets! am i in the wrong program? i purchased VW10 as an upgrade form VW9, and then upgraded again to VW10.5.1, could this have something to do with the problem? thanks
  6. katie, i am experiencing the exact same problem and i am using VW10.5.1. I have tried all the work-arounds, such as reinstalling QT with custom install, but to no avail. please help! i have two animations to do of KD furniture each with 20 seperate sheets! i do not relish spending the next several days watching the blue bar get longer. thnks m bali
  7. Katie, i am experiencing the exact same problem as anais, and i am running VW 10.5.1. i have done everything suggested here on the BB, including reinstalling QT with custom install. still not working. since i just ponied up for VW 10.5 in March 03, i really don't want to pay out for VW11 yet. any real solutions to this batch render name problem? right now i must render each saved sheet singly and then use photoshop to create my animations (QT is just too cumbersome). running VW10.5.1 on AMD 3GHZ 1GB RAM, SATA and Win2K thanks m
  8. i am attempting to batch render a series of sheets to animate an exploded view of a knock-down chair. i have two problems: is there an easier way to render a series of saved sheets other than opening each one and applying it to the batch jobs? second: what is up with "the os cannot create a file with this job name"? very irritating, especially when the animation involves 20 seperate sheets. using VW10.5.1
