I am losing edges of polygons when I plot sheets with viewports. It only happens on polygons that are in a viewport. Most of the polygon will plot put intermitent edges do not plot. It is dependent on vertexes as an edge will plot between two vertexes and not between the next two. It appears fine on screen and if I plot the original layers and not the viewport it plots just fine. I have changed the sheets dpi setting to 120 with no changes. I have tweaked the viewport's line weight scale and it has no effect. I have changed the original polygon's class, line wt, color, etc. to no avail... All classes are turned to visible on the sheet. The polygons are well within the crop edge.
I have changed the plotter's settings but they have no effect. I am pretty sure it is a Vectorworks issue as when I convert the polygon to lines it will print.
Any ideas?
thx
