sicily80
46 -
Reputation
0 NeutralPersonal Information
Occupation
Architect
Location
Berkeley, CA
Juan at tech support figured out an answer. Apparently the quartz imaging option was checked in VW Prefs - Display and they somehow made things thicker... Thanks for all your help.
Nevermind, I know what you email is. I'll send it along...thanks!
It's happened on two different files I've worked on since the upgrade, and I just tried it on a blank file (with the same results) so I'm assuming it'll happen on all files. I'd be happy to scan in the plots from 12.0 and 12.5 and email it to you for you to see. Please let me know where to send it to. Thanks!
I've updated the OS to 10.4.7, ran verify and repair permissions...I can not find where the printer repair utility is exactly though the driver was updated. Is there anything else in the update that can trigger this? Should I go just back to 12.0? Thanks!
Hi Katie, I found a driver update, installed it, and had the same poor results with 12.5 and HP 800. I pulled the same file to another computer that has 12.0, plotted it out on the same plotter and it looked fine. I do think there's a compatibility issue with 12.5 and HP 800 and hope there's a fix for it soon. Thanks!
Hi Katie, Our plotter is HP designjet 800 ps and we're running on Mac OS 10.4.3. I'll see if there's an updated driver. Thanks!
hi cbaarh, the only options I have is the latter option where its that normal Century Gothic with VW setting to Bold. Again the plotting of the font was fine in 12, and all of a sudden got extra Bold with the update. I've been looking around to see if there are settings in 12.5 to make it a normal Bold, but have not been successful. It's a bit annoying when things look different after an update, and no changes have been made to a file...
We use Century Gothic (bold) as a font for our title page, and after I updated to 12.5 the font plots out more bold than before. Its very noticeable on the sheet and looks quite awkward actually, however it looks the same on the screen. Any reason for that? Any fix? We didn't have that problem with any previous updates. Thanks!
View one symbol with 2 different line weights
sicily80 replied to sicily80's topic in General Discussion
Thanks for the replies. Mechanix - That is what I'm doing. People in my office tends to think that the line weight should be lighter on a M/E plan or a structural plan even when its on another layer. I've leary of upgrading to VW12 at this moment, since some of the changes on VW11 is still bugging me and I'm just getting use to them... -
Hi! We have been makng our floor plans into a symbols so that we can reuse the symbols in our mechanical/electrical and structural plans. The reason for this is so any changes made in the floor plan becomes a global change throughout, and there is no worries of inconsistency throughout. My question is whether or not it's possible to view one symbol with one line weight for floor plans, and have the same symbol be of a lighter/smaller line weight on a structural plan? Either through classes or scripts? We're using Fundamentals 11.5. Thanks! Cecil
I have had the same problems: 1. Door swing line weights changing 2. Door end caps missing 3. Cased openings looking like windows 4. Window lineweights looking changing The upgrade or reworking of these tools have been non-productive and problematic. I've given up on the new door and window tools, and decided to replace the new plugins with the old V11 door and window plugin. I like the layout better anyways.
Thanks! I may try working on a clean file to see what happens. Kinda strange that out-dated fonts have such an effect on walls. This maybe the reason for other weird stuff that's happening. Thanks again!
Hi! I've been experiencing random crashes while inserting doors and windows. Below is the crash report from apple. Thanks! Cecil Date/Time: 2005-05-12 10:36:04 -0700 OS Version: 10.3.8 (Build 7U16) Report Version: 2 Command: VectorWorks Path: /Applications/VectorWorks 11.5/VectorWorks Version: ??? (???) PID: 1465 Thread: 0 Exception: EXC_BAD_ACCESS (0x0001) Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x0000000c Thread 0 Crashed: 0 VectorWorks 0x02c90728 0x2008000 + 0xc88728 1 VectorWorks 0x02c8d114 0x2008000 + 0xc85114 2 VectorWorks 0x02c8cd34 0x2008000 + 0xc84d34 3 VectorWorks 0x02c8a6dc 0x2008000 + 0xc826dc 4 VectorWorks 0x02c888ac 0x2008000 + 0xc808ac 5 VectorWorks 0x02c88774 0x2008000 + 0xc80774 6 VectorWorks 0x02283ab0 0x2008000 + 0x27bab0 7 VectorWorks 0x02f2fe18 0x2008000 + 0xf27e18 8 VectorWorks 0x02f1df18 0x2008000 + 0xf15f18 9 VectorWorks 0x02f2067c 0x2008000 + 0xf1867c 10 VectorWorks 0x02f2f080 0x2008000 + 0xf27080 11 VectorWorks 0x02f1e934 0x2008000 + 0xf16934 12 VectorWorks 0x02a9815c 0x2008000 + 0xa9015c 13 VectorWorks 0x02a99398 0x2008000 + 0xa91398 14 VectorWorks 0x02a98c24 0x2008000 + 0xa90c24 15 VectorWorks 0x02a9a8f8 0x2008000 + 0xa928f8 16 VectorWorks 0x02a9a9ec 0x2008000 + 0xa929ec 17 VectorWorks 0x020f92b0 0x2008000 + 0xf12b0 18 VectorWorks 0x020fc30c 0x2008000 + 0xf430c 19 VectorWorks 0x020ffc3c 0x2008000 + 0xf7c3c 20 VectorWorks 0x0209393c 0x2008000 + 0x8b93c 21 VectorWorks 0x02095f04 0x2008000 + 0x8df04 22 VectorWorks 0x02095dbc 0x2008000 + 0x8ddbc 23 VectorWorks 0x020c3bc0 0x2008000 + 0xbbbc0 24 VectorWorks 0x020bbd3c 0x2008000 + 0xb3d3c 25 VectorWorks 0x020962fc 0x2008000 + 0x8e2fc 26 VectorWorks 0x0209ce9c 0x2008000 + 0x94e9c 27 VectorWorks 0x020a63bc 0x2008000 + 0x9e3bc 28 VectorWorks 0x020a63bc 0x2008000 + 0x9e3bc 29 VectorWorks 0x020a63bc 0x2008000 + 0x9e3bc 30 VectorWorks 0x020a63bc 0x2008000 + 0x9e3bc 31 VectorWorks 0x020a63bc 0x2008000 + 0x9e3bc 32 VectorWorks 0x020a63bc 0x2008000 + 0x9e3bc 33 VectorWorks 0x020a63bc 0x2008000 + 0x9e3bc 34 VectorWorks 0x02061f4c 0x2008000 + 0x59f4c 35 VectorWorks 0x020a7a50 0x2008000 + 0x9fa50 36 VectorWorks 0x02079b60 0x2008000 + 0x71b60 37 VectorWorks 0x020a7874 0x2008000 + 0x9f874 38 VectorWorks 0x02093f44 0x2008000 + 0x8bf44 39 VectorWorks 0x02093b80 0x2008000 + 0x8bb80 40 VectorWorks 0x0207d968 0x2008000 + 0x75968 41 VectorWorks 0x02091650 0x2008000 + 0x89650 42 VectorWorks 0x020913dc 0x2008000 + 0x893dc 43 VectorWorks 0x0207b044 0x2008000 + 0x73044 Thread 1: 0 libSystem.B.dylib 0x900074c8 mach_msg_trap + 0x8 1 libSystem.B.dylib 0x90007018 mach_msg + 0x38 2 com.apple.CoreFoundation 0x90191700 __CFRunLoopRun + 0x350 3 com.apple.CoreFoundation 0x90195e8c CFRunLoopRunSpecific + 0x148 4 com.apple.audio.CoreAudio 0x90732f80 _ZN10HALRunLoop9OwnThreadEPv + 0x104 5 com.apple.audio.CoreAudio 0x907391e0 _ZN9CAPThread5EntryEPS_ + 0x30 6 libSystem.B.dylib 0x900246e8 _pthread_body + 0x28 Thread 2: 0 libSystem.B.dylib 0x9001a4ac syscall + 0xc 1 ...ple.CoreServices.OSServices 0x906200cc BSD_waitevent + 0x2c 2 ...ple.CoreServices.OSServices 0x9061cac0 CarbonSelectThreadFunc + 0xb0 3 libSystem.B.dylib 0x900246e8 _pthread_body + 0x28 Thread 3: 0 libSystem.B.dylib 0x90016f48 semaphore_wait_signal_trap + 0x8 1 libSystem.B.dylib 0x9000e790 _pthread_cond_wait + 0x270 2 ...ple.CoreServices.OSServices 0x90627300 CarbonOperationThreadFunc + 0x50 3 libSystem.B.dylib 0x900246e8 _pthread_body + 0x28 Thread 4: 0 libSystem.B.dylib 0x90016f48 semaphore_wait_signal_trap + 0x8 1 libSystem.B.dylib 0x9000e790 _pthread_cond_wait + 0x270 2 ...ple.CoreServices.OSServices 0x9061ef8c WaitForSyncDone + 0x4c 3 ...ple.CoreServices.OSServices 0x906129a4 RecvData + 0x2a4 4 ...ple.CoreServices.OSServices 0x906502ec OTRcvUData + 0x3c 5 VectorWorks 0x02162320 0x2008000 + 0x15a320 6 VectorWorks 0x02163740 0x2008000 + 0x15b740 7 VectorWorks 0x02f4a14c 0x2008000 + 0xf4214c 8 VectorWorks 0x02f4a574 0x2008000 + 0xf42574 9 VectorWorks 0x02f49c28 0x2008000 + 0xf41c28 10 ...ple.CoreServices.CarbonCore 0x903220d8 _MP_CFMTaskProc + 0x20 11 ...ple.CoreServices.CarbonCore 0x902c6d88 PrivateMPEntryPoint + 0x4c 12 libSystem.B.dylib 0x900246e8 _pthread_body + 0x28 Thread 5: 0 libSystem.B.dylib 0x90016f48 semaphore_wait_signal_trap + 0x8 1 libSystem.B.dylib 0x9000e790 _pthread_cond_wait + 0x270 2 ...ple.CoreServices.CarbonCore 0x90309804 MPWaitOnSemaphore + 0xb8 3 VectorWorks 0x0215fa98 0x2008000 + 0x157a98 4 VectorWorks 0x02f505a8 0x2008000 + 0xf485a8 5 VectorWorks 0x02f4fc38 0x2008000 + 0xf47c38 6 ...ple.CoreServices.CarbonCore 0x903220d8 _MP_CFMTaskProc + 0x20 7 ...ple.CoreServices.CarbonCore 0x902c6d88 PrivateMPEntryPoint + 0x4c 8 libSystem.B.dylib 0x900246e8 _pthread_body + 0x28 PPC Thread State: srr0: 0x02c90728 srr1: 0x0200f030 vrsave: 0x00000000 cr: 0x44002282 xer: 0x20000004 lr: 0x02c8f044 ctr: 0x02c8eb60 r0: 0x00000000 r1: 0xbfffe9c0 r2: 0x0040d000 r3: 0x00000000 r4: 0xffffffff r5: 0x00000000 r6: 0x074ea160 r7: 0x00000004 r8: 0x0897b90c r9: 0xa00011ac r10: 0x0000077d r11: 0x08b02004 r12: 0x00424f14 r13: 0x00000000 r14: 0x00000000 r15: 0x00000000 r16: 0x00000000 r17: 0x00000000 r18: 0x00000000 r19: 0x00000000 r20: 0xbffffe84 r21: 0xffffffff r22: 0xbffffc40 r23: 0xbfffec10 r24: 0x00000000 r25: 0x00000000 r26: 0x00536998 r27: 0x089dc7b0 r28: 0x00000001 r29: 0x00536998 r30: 0x088d82a0 r31: 0x00000000 Binary Images Description: 0x1000 - 0x9fff VectorWorks /Applications/VectorWorks 11.5/VectorWorks 0xb5000 - 0xb578d Plug-In Support?? PEF binary: Plug-In Support?? 0xbc000 - 0xc3833 OpenGLLibrarypwpc PEF binary: OpenGLLibrarypwpc 0xc3840 - 0xc426b OpenGLUtilitypwpc PEF binary: OpenGLUtilitypwpc 0xc4270 - 0xc4629 OpenGLMemory PEF binary: OpenGLMemory 0x287000 - 0x2d29b1 CarbonLibpwpc PEF binary: CarbonLibpwpc 0x2d29c0 - 0x2eacad Apple;Carbon;Multimedia PEF binary: Apple;Carbon;Multimedia 0x2ec1f0 - 0x2edf7b Apple;Carbon;Networking PEF binary: Apple;Carbon;Networking 0x3119e0 - 0x311a71 CFMPriv_AGL PEF binary: CFMPriv_AGL 0x311db0 - 0x311e62 CFMPriv_CoreFoundation PEF binary: CFMPriv_CoreFoundation 0x312050 - 0x312105 CFMPriv_DVComponentGlue PEF binary: CFMPriv_DVComponentGlue 0x312320 - 0x3123c3 CFMPriv_QuickTime PEF binary: CFMPriv_QuickTime 0x312440 - 0x3124b7 CFMPriv_System PEF binary: CFMPriv_System 0x3127f0 - 0x3128c0 CFMPriv_CarbonSound PEF binary: CFMPriv_CarbonSound 0x3128d0 - 0x3129a3 CFMPriv_CommonPanels PEF binary: CFMPriv_CommonPanels 0x312a70 - 0x312b2b CFMPriv_Help PEF binary: CFMPriv_Help 0x312b30 - 0x312bfa CFMPriv_HIToolbox PEF binary: CFMPriv_HIToolbox 0x312c70 - 0x312d46 CFMPriv_HTMLRendering PEF binary: CFMPriv_HTMLRendering 0x312dc0 - 0x312e93 CFMPriv_ImageCapture PEF binary: CFMPriv_ImageCapture 0x312f20 - 0x313005 CFMPriv_NavigationServices PEF binary: CFMPriv_NavigationServices 0x313080 - 0x313156 CFMPriv_OpenScripting?MacBLib PEF binary: CFMPriv_OpenScripting?MacBLib 0x313230 - 0x3132ee CFMPriv_Print PEF binary: CFMPriv_Print 0x313310 - 0x3133dd CFMPriv_SecurityHI PEF binary: CFMPriv_SecurityHI 0x313460 - 0x313542 CFMPriv_SpeechRecognition PEF binary: CFMPriv_SpeechRecognition 0x3135c0 - 0x313693 CFMPriv_CarbonCore PEF binary: CFMPriv_CarbonCore 0x313710 - 0x3137e3 CFMPriv_OSServices PEF binary: CFMPriv_OSServices 0x3138c0 - 0x313982 CFMPriv_AE PEF binary: CFMPriv_AE 0x313990 - 0x313a55 CFMPriv_ATS PEF binary: CFMPriv_ATS 0x313ad0 - 0x313ba7 CFMPriv_ColorSync PEF binary: CFMPriv_ColorSync 0x313c30 - 0x313d13 CFMPriv_FindByContent PEF binary: CFMPriv_FindByContent 0x313d90 - 0x313e6a CFMPriv_HIServices PEF binary: CFMPriv_HIServices 0x313ee0 - 0x313fc0 CFMPriv_LangAnalysis PEF binary: CFMPriv_LangAnalysis 0x314050 - 0x314136 CFMPriv_LaunchServices PEF binary: CFMPriv_LaunchServices 0x314210 - 0x3142e7 CFMPriv_PrintCore PEF binary: CFMPriv_PrintCore 0x3142f0 - 0x3143b2 CFMPriv_QD PEF binary: CFMPriv_QD 0x3144b0 - 0x314599 CFMPriv_SpeechSynthesis PEF binary: CFMPriv_SpeechSynthesis 0x7fb000 - 0x7fb91c VWLibrary5? PEF binary: VWLibrary5? 0x1008000 - 0x160ac38 DWGdirect Library PEF binary: DWGdirect Library 0x1684000 - 0x168985f ExtrudeAlongPath PEF binary: ExtrudeAlongPath 0x168a000 - 0x168f4e7 HelixSpiral? PEF binary: HelixSpiral? 0x1708000 - 0x1742fff com.apple.audio.SoundManager.Components 3.8 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents 0x17b0000 - 0x17b6aaf Duplicate Symbol In Wall PEF binary: Duplicate Symbol In Wall 0x17b7000 - 0x17c94c7 Offset Tool@ PEF binary: Offset Tool@ 0x17ca000 - 0x17cc1c3 MovePage PEF binary: MovePage 0x17de000 - 0x17e17cf Resize PEF binary: Resize 0x17e2000 - 0x17e517b Shear PEF binary: Shear 0x17e6000 - 0x17e7dab TapeMeasureTool? PEF binary: TapeMeasureTool? 0x17e8000 - 0x17f5183 AlignDistributeLib PEF binary: AlignDistributeLib 0x2008000 - 0x311059f VectorWorks PEF binary: VectorWorks 0x31105a0 - 0x3146701 MSL_All_Carbon.Shlb Rel PEF binary: MSL_All_Carbon.Shlb Rel 0x3146710 - 0x31f457b OpenDWGLib PEF binary: OpenDWGLib 0x31f4580 - 0x37b6bf1 SMNMTLib PEF binary: SMNMTLib 0x37b6c00 - 0x3990ef4 SMNurbsLib PEF binary: SMNurbsLib 0x3990f00 - 0x3b82b91 SMHWTransLib PEF binary: SMHWTransLib 0x5e34000 - 0x5e70fff com.apple.iSightAudio 6.5.2 /Library/Audio/Plug-Ins/HAL/iSightAudio.plugin/Contents/MacOS/iSightAudio 0x6506000 - 0x6512f8f EditShader?? PEF binary: EditShader?? 0x6513000 - 0x652f8ab ExtendedPropertiesitShader PEF binary: ExtendedPropertiesitShader 0x6541000 - 0x662ccc5 GeometryLib? PEF binary: GeometryLib? 0x6693000 - 0x669f00b RenderSettings PEF binary: RenderSettings 0x66a0000 - 0x6719c6a VectorScriptEditor PEF binary: VectorScriptEditor 0x672d000 - 0x6746c6f VS SharedLib PEF binary: VS SharedLib 0x6747000 - 0x691f191 XMLLib PEF binary: XMLLib 0x698f000 - 0x69a15df FramingMember PEF binary: FramingMember 0x69c4000 - 0x69d2f07 TaperedExtrude PEF binary: TaperedExtrude 0x69d3000 - 0x69d8547 Textured Prop PEF binary: Textured Prop 0x71f2000 - 0x71fe207 Duplicate Along Pathchitectt PEF binary: Duplicate Along Pathchitectt 0x721c000 - 0x721e93b Trim Tool7+p PEF binary: Trim Tool7+p 0x721f000 - 0x7227e53 Eyedropper Tool PEF binary: Eyedropper Tool 0x722d000 - 0x72e1b7e Workspace EditorWalls item PEF binary: Workspace EditorWalls item 0x72fc000 - 0x731d61b Purge PEF binary: Purge 0x731e000 - 0x731ffb3 Guides PEF binary: Guides 0x7320000 - 0x7322913 Fit To Objects PEF binary: Fit To Objects 0x7323000 - 0x7361bb7 CheckSpelling O PEF binary: CheckSpelling O 0x7362000 - 0x736f7b3 TrueType To Polyline PEF binary: TrueType To Polyline 0x7370000 - 0x737c9fb ExtrudeAlongPathMenu PEF binary: ExtrudeAlongPathMenu 0x737d000 - 0x73844bf TaperedExtrudeMenution VersionB" PEF binary: TaperedExtrudeMenution VersionB" 0x7385000 - 0x738ebc3 HelixSpiralMenu PEF binary: HelixSpiralMenu 0x738f000 - 0x7394dbb Roofer PEF binary: Roofer 0x7395000 - 0x739f5b7 Export Quicktime Movie]? PEF binary: Export Quicktime Movie]? 0x73a0000 - 0x73a2baf Orbit Animator PEF binary: Orbit Animator 0x73a3000 - 0x73bf5f7 Path Animator PEF binary: Path Animator 0x73c0000 - 0x73c5cf3 Sun Position PEF binary: Sun Position 0x73c6000 - 0x73c7363 Align Layer Views PEF binary: Align Layer Views 0x748a000 - 0x748cfff com.apple.textencoding.unicode 1.6.4 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings 0x7329f000 - 0x73967fff com.apple.QuickTimeComponents.component 6.5.2 /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents 0x88be0000 - 0x88becfff com.apple.agl 2.5 (AGL-2.5) /System/Library/Frameworks/AGL.framework/Versions/A/AGL 0x8be30000 - 0x8be31fff DVComponentGlue /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue 0x8c390000 - 0x8c3d1fff com.apple.QuickTimeFirewireDV.component 6.5.2 /System/Library/QuickTime/QuickTimeFirewireDV.component/Contents/MacOS/QuickTimeFirewireDV 0x8e990000 - 0x8ea21fff com.apple.QuickTimeMPEG4.component 6.5.2 /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4 0x8fe00000 - 0x8fe4ffff dyld /usr/lib/dyld 0x90000000 - 0x90122fff libSystem.B.dylib /usr/lib/libSystem.B.dylib 0x90190000 - 0x9023dfff com.apple.CoreFoundation 6.3.6 (299.33) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x90280000 - 0x904f9fff com.apple.CoreServices.CarbonCore 10.3.6 (10.3.5) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x90570000 - 0x905dffff com.apple.framework.IOKit 1.3.6 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x90610000 - 0x9069afff com.apple.CoreServices.OSServices 3.0.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x90700000 - 0x90700fff com.apple.CoreServices 10.3 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x90720000 - 0x90787fff com.apple.audio.CoreAudio 2.1.2 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x907f0000 - 0x907f9fff com.apple.DiskArbitration 2.0.4 /System/Library/PrivateFrameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x90810000 - 0x90810fff com.apple.ApplicationServices 1.0 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x90830000 - 0x9089ffff libobjc.A.dylib /usr/lib/libobjc.A.dylib 0x90910000 - 0x90983fff com.apple.DesktopServices 1.2.3 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x909f0000 - 0x90b4bfff com.apple.Foundation 6.3.5 (500.56) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x90c30000 - 0x90c4afff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x90c60000 - 0x90cc2fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x90d00000 - 0x90d1bfff com.apple.SystemConfiguration 1.7.1 (???) /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x90d40000 - 0x90d40fff com.apple.Carbon 10.3 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x90d60000 - 0x90d6bfff com.apple.opengl 1.3.8 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x910b0000 - 0x91101fff com.apple.bom 1.2.5 (63.2) /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom 0x912a0000 - 0x912bdfff com.apple.audio.SoundManager 3.8 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound 0x912e0000 - 0x912f7fff com.apple.LangAnalysis 1.5.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x91320000 - 0x913dffff ColorSync /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x91460000 - 0x91473fff com.apple.speech.synthesis.framework 3.2 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x914a0000 - 0x91509fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering 0x91560000 - 0x91619fff com.apple.QD 3.4.65 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x91670000 - 0x916a8fff com.apple.AE 1.4 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x916e0000 - 0x91773fff com.apple.print.framework.PrintCore 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x917e0000 - 0x917f0fff com.apple.speech.recognition.framework 3.3 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x91810000 - 0x9182afff com.apple.openscripting 1.2.1 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x91850000 - 0x91860fff com.apple.ImageCapture 2.1.5 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x91890000 - 0x9189cfff com.apple.help 1.0.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x918c0000 - 0x918cdfff com.apple.CommonPanels 1.2.1 (1.0) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x918f0000 - 0x9193efff com.apple.print.framework.Print 3.3 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x91990000 - 0x9199bfff com.apple.securityhi 1.2 (90) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x919c0000 - 0x91a33fff com.apple.NavigationServices 3.3.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices 0x91a90000 - 0x91a90fff com.apple.audio.units.AudioUnit 1.3.2 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x91ab0000 - 0x91ac4fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib 0x91ae0000 - 0x91aebfff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib 0x91b10000 - 0x91b2afff libPDFRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libPDFRIP.A.dylib 0x91b50000 - 0x91b5ffff libPSRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libPSRIP.A.dylib 0x91b80000 - 0x91b93fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib 0x91bb0000 - 0x91d45fff com.apple.QuickTime 6.5.2 /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime 0x92070000 - 0x92096fff com.apple.FindByContent 1.4 (1.2) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent 0x920c0000 - 0x922a7fff com.apple.security 2.4 (177) /System/Library/Frameworks/Security.framework/Versions/A/Security 0x92430000 - 0x92468fff com.apple.LaunchServices 10.3.5 (98.4) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x92740000 - 0x92777fff com.apple.CFNetwork 1.2.1 (7) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x927d0000 - 0x92b54fff com.apple.HIToolbox 1.3.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x92d30000 - 0x92d80fff com.apple.HIServices 1.4.1 (0.0.1d1) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x935d0000 - 0x938a8fff com.apple.CoreGraphics 1.203.30 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x939a0000 - 0x939b4fff libcups.2.dylib /usr/lib/libcups.2.dylib 0x939d0000 - 0x939d4fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib 0x93b50000 - 0x93bf3fff com.apple.audio.toolbox.AudioToolbox 1.3.2 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x94060000 - 0x94078fff com.apple.WebServices 1.1.1 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore 0x945b0000 - 0x945b9fff libz.1.dylib /usr/lib/libz.1.dylib 0x94610000 - 0x9462afff libresolv.9.dylib /usr/lib/libresolv.9.dylib 0x94650000 - 0x946affff com.apple.SearchKit 1.0.2 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x94a30000 - 0x94af5fff libxml2.2.dylib /usr/lib/libxml2.2.dylib 0x94b20000 - 0x94badfff com.apple.ink.framework 101.1.3 (55.10) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x954c0000 - 0x95ac6fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x95b20000 - 0x95df0fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x95e40000 - 0x95eadfff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x95f00000 - 0x95f20fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x968d0000 - 0x969b2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib 0x96a20000 - 0x96ae2fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib 0x96b40000 - 0x96b6efff libssl.0.9.7.dylib /usr/lib/libssl.0.9.7.dylib 0x96bf0000 - 0x96c7ffff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x96cb0000 - 0x96d9efff libiconv.2.dylib /usr/lib/libiconv.2.dylib 0x96e80000 - 0x96e90fff com.apple.vecLib 3.0.3 (vecLib 3.0.3) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib 0x97510000 - 0x97518fff libbsm.dylib /usr/lib/libbsm.dylib
Yeah, we've tried running disk utility to repair permissions already and re-installing the update. Is there anything else we can try?
Let me know if that's enough information. I'm not quite sure where to look for driver version??
