kd_archdesign
    7
    Never
Reputation
0 Neutral
  1. Thanks. I just read the viewport FAQ and foudn it very helpful.
  2. The new image compression in VW 11 is Incredible. My 18 meg file is only 1.2 megs in VW 11. However, I'm not sure what the difference is between PNG and JPG compression. Which do you reccomend? [ 05-04-2004, 03:36 PM: Message edited by: kd_archdesign ]
  3. It sounds like you're looking for a raster to vector converter software. you should check out Scan To CAD, http://www.nemetschek.net/partners/plugins/scan2cad.html These programs are specifically designed to take bitmap CAD drawing and convert them into Vector drawing. The process is pretty easy but often require "clean up".
  4. I just received my copy of VW 11 and am very impressed. It seems to be rock sold on my duel G5. What I was most impressed with is how easy the transition seems to be going. No major interface changes, nothing seems to be missing, and things work as I expect:> I love the little tweaks: dash lines now draw correctly, trim and extend are much improved, you don?t have to hit the enter key to lock values in the data display bar, how dimensions can now go into ANY class,how groups go into the active class,the text formatting options in the IO palette? But the Viewport feature is by far the biggest improvement. As a long time ACAD users, NNA really got this one right. Compared to ACAD, VW viewports are much easier to use, and will have a dramatic positive effect on how I create my drawing sets as well as presentation boards. Great Job!
  5. Mada, I just received my copy of VW 11 and Importing and Exporting 3D modles between VW and ACAD is drmatically improved. VW 11 now supports the .sat file format which is ACAD's native 3D format, so models 3D sold models come across one-to-one.
  6. I was taking a look at the new VW 11 website and found that NNA has create some pretty cool movies that describe some of the new capabilties, http://www.nemetschek.net/vectorworks/movies.html 11 looks like a very substancial release.
