22 -
Everything posted by rafaelmartins.95
Hello, I'm trying to update some viewports in "Realistic Interior Final" on a university computer. I created the file on my own computer (VW2021). The university computer should be better than mine and has VW2020. When I open the file, the viewports are already in Realistic Interior Final, but I need some updating. When I press "update" the viewport freezes and then goes to "wireframe". I try updating again but it doesn't allow me to choose "Realistic Interior Final" anymore, or any other final rendering options. Any help? Thank you!
Hello, I'm trying to create proper architectural section drawings with different materials being sectioned (with different hatches and so on). I can't seem to find a way to make this automatic when creating a section viewport. I've changed the "graphic attributes" of the individual classes that I've created for the different materials but I can't make those attributes show in the viewport. It seems to me that this should be possible? Help would be appreciated!! Thank you! 🙂
@Tom W. I turned that off as well 😕
Hey guys, So I'm trying to render my model but, no matter the quality of the viewport/light options or definitions of the site model itself, these green lines (contours) keep showing on the render. Is there a way for me to render the site realistically? Thank you!
@Tony Kostreski Yes I've got it! Thank you so much!
Hello, I'm trying to create a site model. I've drawn contour lines that elevate 1m at a time. I'd now like to interpolate intermediate lines in between the intervals but I'm not sure how to do that.
@Sebastiaan Well that was easy! Thank you!!
Hello, So I'm creating a 3D Building and I've separated it in different layers and classes. Now, as I'm working, I'll naturally move inbetween layers/classes and this has been happening (check photos): I'm working on the tower, for instane, go from top/plan view to a costum 3D view and the rest of the building (on a different layer), as well as the 2D page remains in top/plan view. Also, as you can see I've got "Show, Snap, Modify Others" on in both layers and classes. This did not happen to me before and I'm not sure why it's happening now. Can anyone help? Thank you very much!! Cheers
So usually, when editing a viewport with a camera view I press "Lighting Options" and the tab would have all of these options: "Options, Quality, Lighting, Edges and Background" Like so: But now, out of nowhere... It's just this: I need to make ajustments in the other sections as well. Did I turn it off somehow?
VBvisual plant tool not working
rafaelmartins.95 replied to rafaelmartins.95's topic in Architecture
@zoomer How do you do that? -
Hello, I'm trying to place trees in my model. When I select a tree, any tree, from the list in the VBvisual tree tool, I place it and then nothing happens. It's as if I did nothing. I don't understand.
Viewport Update taking ages to update
@Pat Stanford Hello Pat, thank you for your reply. I've been able to solve the issue by copying my model into another file. I was trying to update the viewports into "hidden line". I forgot to type that in the post. My file is watermarked because I'm a student. -
So I'm trying to sort my design sheet with some plans and sections. Up until today it was working fine, the viewports took a little bit to update but nothing tragic. Today, however, despite not having any considerable changes to the 3D Model, the uptades are taking forever, to the point where it's not possible for me to work anymore. I left the programme updating all the viewports for almost two hours and it was not done. Now I have been waiting for 40 minutes for just one and it doesn't show any sings of finishing. I don't understand... Is anything wrong with my file? Winter Garden.vwx
Curved Corner in a Curved Frame
rafaelmartins.95 replied to rafaelmartins.95's topic in General Discussion
@markdd @Tom W. Yeah thank you guys as well. I also used this suggestion for something else! :) -
@jeff prince It worked! Thank you so much! I didn't know about the extract tool so that was very handy. I'm just now learning how to use Vectorworks for uni, so this was very helpful! -
Hello! I want to create a curved corner in this frame but I'm not sure how. It is supposed to be the same as the one next to it but this wall is curved. I've already converted all the lines of the frame into NURBS and they are already composed into one object. (I will later use it as a path to extrude a profile along). I'm just not sure how to do that curved bit. I created those spheres there just to visualize where the curves need to go. Can anyone help me? Thanks!
@jeff prince It's solved now, thanks anyway!
@Tom W. Done!! Thank you so much! That's exactly what I needed
@jeff prince the intricate shape of the profile won't bend properly in the corners that way
How do I create a polyline (in order to extrude along path) from two straight lines and two curved lines that are not in the same plane. The goal is to create a curved frame that goes along a curved wall. Which is the easiest way to do this? I can't find anything online...
