Hello,
I currently use Vectorworks Spotlight for my show designs, but then use Capture.se for PreViz. Specifically for the reason that they support fountains, I use a lot of universes, and I have a full license for them. Will eventually move to Vision.
Usually you would use a DWG file exported from Vectorworks to import into Capture. What I am noticing is objects that are considered 2D and 3D (shows this when you select the object), come up as flat images in capture. But if the object is ONLY a 3D image and not also a 2D object, it works perfectly.
My current drawing has a combination of these objects (2D/3D and 3D Only), but Im not sure how they got assigned as such. Some identical truss is 2D/3D and some is 3D only.
How do you make an object in Vectorworks a 3D Object only?
Thank you!
