Harold
    26
    Never
Everything posted by Harold
  1. How about in previous versions to version 11.5.? How difficult can it be?
  2. I am thinking seriously in upgrading. However, I would like to learn the software more in depth first. One question: How can I print several drawings in one sheet?
  3. I am using VW-Arch.-Rend. 10.5.1
  4. Hi All, I have been taught ACad from school and now working for Firm, I am also using it. Furthermore, I am used to deal with the viewports from ACad. Now I have been reading that VW 11.5 is including that feature. Great! But how did the previous versions manage to make a presentation sheet without viewports? Thanks! (I will need an answer about that very soon, I am sure)
  5. Harold
    landscaping
    Thank you for the answers. About the windows: I am trying to draw the plan and to have already the elevation done at the same time. I would like to define frame width and lintels also. However, and this is now related to other issue, when I try to see the elevation, the other elements that are 2D (i.e., hatching), don't move. How does VW manage to create elevations?
  6. Thanks. What I found out is that you can draw a polyline and then double click the desired hatching and the area defined by the polilyne will change with the selected pattern. After that, sent the area to the back so I could see the plumbing fixtures on top of the floor. Works great!
  7. More basic questions: How can I add shadows to plants in plan? Is there a way to insert toilets without the partition walls? Where are the sinks and showers? Can I define a new window from an existing one and rename it? Thanks so much.
  8. Is there a way to apply a hatch in a room without having to draw a square to define the boundaries of the hatching?
  9. I have a 44" space between two walls where I need to have a stair. Is there an specific way how to insert it from the toolbar? Everytime I chose the stairs comand, it inserts one with the arrow indicating DOWN and also one of the walls always moves from its original locatino. How can I insert it going up? And also how I am supposed to create the cut line for the treads above 3'6" from floor level?
  10. Alright Cipes, you just opened another window of opportunity for adventure! i did not know that about workspace. Cool. Good machine (G5) by the way (I added that in my signature too, just to be supportive!)
  11. Thanks CipesDesign, that was the right way to upload them! I also tried to upload landscaping information and still it seems to be more to be discovered!!! Cool!
  12. I got VW approx. a year ago. I have only used it for one competition in my last semester in Arch. school last Spring, and then, after getting a REAL job, I have been forced to keep using AutoCad Desktop. Very sad. My questions are still very much basic: * Where can I find the list of all the hatches I have available (I have Architects and RenderWorks)? The only one I can see once inside my drawings, is a diagonal 45 degrees. Nothing else. *In the same order, where can I find (and upload?) all the landscape elements to insert into a plan/elevations? I found a series of files through the finder and clicking on them, they open as an additional regular VW file, and the only way i have found to bring trees into my existing drawings has been to copy a tree with a regular "copy-paste" procedure. I would really appreciate any input!
  13. How about for those who just got VW 10? No people at all?
  14. IT WAS THERE!!! Thanks! When you said that I can install it did you mean from the CD or is it in some folder already in the hard drive?
  15. I am trying to create walls from polygons, but it seems that what the manual for Vectorworks explains, does not apply for VW Architect (and also got its manual). Is that right? I can't find the option "create walls from polygons". Instead, I can create space first, and then try to create walls from spaces. (and I am not even sure if it is because of the scale I am working with, 1:1, I don't see the walls anywhere!) Thanks so much. I'd appreciate it.
  16. It seems that those windows (with the sizes options) appears only the very first time a space is created. The subsequent space definitions take the same format than the first one. How about editing the one already created? Thanks,
  17. The IDs I am referring to are the Space name tags that are created when a space is defined. They are huge! in comparison with the scale I am working with.
  18. I am trying to insert IDs to spaces, but the font size seems to not correspond with the scale of the actual layer. Is there a way to set the text in correspondence with the space?
  19. Harold
    Axonometric
    Hi Robert, I am working right now in two projects: one is a 10x10 room where we have to develop details as well as sections and elevations. I have the detail in 2D already. How could I go from there to a section, through 3D? The other one is a convention center. A bigger project, more complex than the first. Basically I have steel structure all over the place (ribs Gehry's type) and I am not sure how could I use VW to my advantage and maybe create 3d images at the same time with my 2Ds.
  20. Harold
    Axonometric
    So now, how can I create a hybrid? I went through all the menus and could not figure it out (chosing the object first, then after, etc). Thanks!
  21. Harold
    Axonometric
    what does PIO mean? I have already the 2D drawing, can I then transform it into a Hybrid or is it too late? I am reading the manual, but maybe your answer will come faster! Thanks so much!
  22. Harold
    Axonometric
    I guess what I meant was a "whole" 3D object. For what I understood from the manual, in order to use an axonometric view I have to create only 3d objects. Am I wrong? (I hope so). I know when I change the view, there is a grid in an axonometric view but every line I try to draw still is in 2D, plan view. The only way I found to draw lines in axon view is pressing the shift key at the same time I draw so I would get a line diagonal 30 degrees.
  23. Thanks Robert, I thought "fit to objects" does actually what it says but only on the screen, not in paper.
  24. Is there a way to draw an axonometric without having to create a 3D compound? Or for that matter, is there a way to set my 2D drawing in an axon view?
  25. hey All! Is there a way that I could print a whole plan without any scale in particular but completely filling one page (letter, tabloid, etc) ? (almost like the Layout/viewport option in ACad) How can I do that? I have a big problem trying to figure out how the scaling mechanism works in VW. I have tried to group a series of lines, copy them, paste them, and extend the edges in an arbitrary way until they fit the page. Any advise? I'd appreciate it.
