Roy Wimpenny
    5
Everything posted by Roy Wimpenny
  1. From experimenting in different instances of 2021 Sometimes truss objects show in 3D, it's more than likely they do not. Sometimes the texture fix works, sometimes it does not. Same with rotating the object in 3D components. I'm reverting back to 2020 for new projects at the moment, I value my sanity too much. Do the VW monitor this forum at all? I've submitted this issue to support in the past and they've got the file working, but not fixed the underlying issues.
  2. Ah ok. I should have known that, sorry. So the texture change did work. Once. But didn't work subsequent times If we're not reassigning the default texture assigned to the VWX library, this is just a temporary workaround for each object in each file and not a long term solution. Are there any ideas for a permanent fix? Also I'm a little skeptical of this solution as it doesn't explain why sometimes objects show and sometimes don't (As in above illustrations) Thanks for all your help so far chaps!
  3. Unless I'm missing something.... I don't get an option to 'edit 3d components' when right clicking in resource manager. FYI I'm now on SP2 2021
  4. To Illustrate these are two tabs in the same file. Both are using the same type of truss. S
  5. Hey Hey, I've been having this issue with truss since I upgraded to 2021, I've just updated to SP1 and I'm still having the same problem. The issue is fairly random, sometimes truss is visible in 3D, sometimes I just get internal bracing, sometimes just the main chords, sometimes I see nothing at all. I can copy and paste everything to a new file, sometimes It will show, sometimes it will make no difference. Truss objects (at least for me) are saying the have no Edit behavior, so I cannot apply the texture fix mentioned above. I'm tearing my hair out. It has to be something simple if not everyone is having the same issue. Please help! Roy
