H.Lagos
    5
Reputation
0 Neutral
Personal Information
  • Location
    Canada
  1. Has anyone encountered this issue where if I create a section viewport, it created a cut 2D plan and the option to change the projection is greyed out? I have also tried copying other section viewports lines that show the building correctly, but the results are the same. The projection options are also absent in the OIP. VW2022 SP6 MAC Monterrey 12.6.3 M1 MAX
  2. VW 2022 SP4. MACOS 12.5 MacBook Pro M1 Hi, I am unable to get a guard created with the railing tool to show the panel texture in section viewports for an elevation. The texture shows up in 3D (perspective or orthogonal) but not in the sheet layer though the viewport. The texture is a perforated metal png with transparency, is that why? I have tried turning all classes on in the viewport but no luck. Image below shows sheet layer on the right and design layer on the left. The top guard was modeled as a railing while the others as a generic wall with texture.
  3. @Wes Gardner Hi Wes, I will do that. Thank you for the reply.
  4. I am working on a Working File in VW 2021 SP02 and as I was trying to change the Top Bound settings of a wall, I noticed that I no longer had any of the levels associated to the design layers (See Image 1 & Image 2 for what it should look like). This changed the Z value of all the slabs and stairs to match L01, yet, all the walls were where they were supposed to be. It also changed the default story elevation value of some but not all story levels to a negative x number that made the level align with L01. To be honest, I am not sure if it is something I clicked on or a bug with shared project files. Either way, I appreciate any advice you can give me. Thank you!
