tom kyler_dup1
Content Count
120 -
Community Reputation
1 NeutralAbout tom kyler_dup1
Rank
Journeyman
Personal Information
Occupation
engineer
Homepage
n/a
Hobbies
sailing, woodworking, metalworking
Location
san antonio
Nurbs curve exactly thru 3D locus points
tom kyler_dup1 replied to Technoflash's topic in Solids Modeling
Here's a thought that's been discussed before. Clearly there's a resolution setting for both 2D and 3D in VW. The resolution setting is a way for the display code to approximate the internal code representing the nurbs curve. So then, a nurbs curve can have high precision in memory, but be approximated on screen such that it draws on screen faster. I'm guessing Nemetschek has picked an upper limit of how much resolution it will display a nurbs curve on-screen...using the "very high" setting....and it appears that the resolution chosen by Nemetschek is not high enough for some. See the screenshot below. The first three views would indicate that the nurbs curve does indeed pass through all the loci..but when you zoom in, it clearly does not pass through the loci and in addition, the curve is segmented...these screenshots were taken with the all resolutions maxed out to very high. If you've ever found yourself trying to write code to draw a curve on-screen, you'll find yourself drawing a bunch of short line segments to approximate the curve...and if you've ever done a real good job of drawing a curve on screen by using so many line segments, then you'll find yourself trying to explain to end users why your curves redraw so slow. With regards to hard segments on your lofted hull, I can't explain that without seeing the original file...but then again, since the past post was almost a month ago, I could be standing in this room all by myself talking at the walls! [ 10-04-2005, 06:57 PM: Message edited by: tom kyler ] -
I must have forgot something...seems like I've succesfully done this before Anyways, I'm trying to encrypt a existing command plug-in I wrote.(*.vsm) ..so I can pass it to some others using the "encrypt" command takes me to a dialog box to select a text file; however, the plug-in exists as a *.VSM file and cannot be selected. Selecting a plain text file creates a encrypted VW file...but I don't want a VW file, I want a plug-in that can be put in the plug-ins folder. I want an encrypted plug-in (*.vsm) What as I missing? [ 08-30-2005, 12:09 PM: Message edited by: tom kyler ]
Thanks Rick...I caught it in the VW documentation....was looking in the wrong place. Thanks for the reply!
Look on the next page...there's a forum post on "3D snapping"
Duplicate array (circular) and loft a 3D object?
tom kyler_dup1 replied to Steve Barrett's topic in Solids Modeling
Steve, read this thread and see if you catch what's going on. Lamberto has a script that will allow you to do this in plan view...here's the link to the forum posting. The only unknown is whether or not the scipt allows a radius of 0, if you have any questions, you can repost and get some help http://techboard.nemetschek.net/ubb/ultimatebb.php?ubb=get_topic;f=3;t=000176 -
A guy who does as much 3D as I do should know this...but when using the pink working plane grid, can you dump the ground grid....it's a real mess in isometric views. If not, then definitely add that option to future versions. [ 03-27-2005, 03:56 PM: Message edited by: tom kyler ]
Your 2D polygon that you used to extrude your shape probably isn't closed. Check your orginial 2D polygon to make sure it is closed. There is a checkbox in the object info palette that tells whether or not a polygon is closed. (See image below) You can have a filled polygon and when you extrude it, only the sides will show. It's usually two verticies that are very close together so that you don't notice it until you zoom way way in...that's probably your original problem. [ 03-27-2005, 03:51 PM: Message edited by: tom kyler ]
Vertical Line Perspectives
tom kyler_dup1 posted a question in Wishlist - Feature and Content Requests
Form-Z has an perspective view that keeps vertical lines straight as opposed to exhibiting parallax. This is the standard architectural photographic technique and would be a great addition to the perspective menu. -
layer / class visibility status in OIP
tom kyler_dup1 replied to tom kyler_dup1's question in Wishlist - Feature and Content Requests
Dan, it does do that in the class and layer pull-down menus, but not in the OIP. The idea is to know what classes and layers are visible at the time you are assigning an object a new class/layer as opposed to pulling down a menu to see what's visibile, then going to the OIP to re-assign the class/layer. -
A small convenience would be to show the layer / class visibility status in the pull down menu in the OIP when changing an object's class and/or layer. -
It's that way many times Mat. I'd bet over 70% of user frustration with Vectorworks doesn't come from the software, but from users lack of knowledge about the software. It's a learning process we all go through though...you did the right thing posting here though next time you might ask before making a conclusion. I've certainly embarrassed myself several times by doing that. [ 12-03-2004, 10:52 AM: Message edited by: tom kyler ]
Mat, first ..make sure you switch to the 3D cursor and give it a try. Because you mention that you can see the mis-alignment when switching to plan view...without zooming in really far, I'm guessing you might have used the 2D cursor to move the line. Now I will say this in case you did that, that if you do snap one nurbs curve to a point along another nurbs curve (not the endpoints) and zoom in really far, it may appear they the two curves are not connected, but there is an internal numerical representation of the curve and a numerical representation of the curve for the way it's drawn onscreen, kind of like 2D conversion res approximating a curved line. So even though it may appear the two curves are not joined, they are numerically joined for practical purposes, certainly for creating other geometry. Besides, you have to zoom in really close to see this anyways. As far as snapping endpoints of nurbs curves using the 3D cursor, you can zoom in as far as you want and they'll be joined. [ 12-02-2004, 10:50 AM: Message edited by: tom kyler ]
Ron, Without getting into real nitty gritty math, I can tell you that using nurbs curve from the beginning will most certainly increase your chances for success; however, you mention that you have sharp angles...Without seeing your shape I can't say for sure, but whenever I have "breaks" or angles between surfaces, I model them seperately and join them later if possible. Good nurbs modeling requires knowledge and some due diligence in setting up the surfaces. You are approaching your surface creation properly by getting the same number of verticies in proper alignment for the lofting tool. The verticies you're thinking of for point alignment that VW uses are generally the control points, so having the same number of control points on each curve in the loft is the best way to create a surface...and alignment (not necessariliy straight) of the control points in each curve will also help ensure success. A nurbs surface is defined by several factors, but the control points are the independent or definable values used to construct the curve. Try these links below to get a little more insight into nurbs....the first link particularly, though not directly addressing control points give some insight into nurbs surfaces. Constructing a good network of curves to loft a complex surface is definitely tedious and where all the work should go. http://www.cs.mtu.edu/~shene/COURSES/cs3621/LAB/surface/knot-insrt.html http://www.rhino3d.com/nurbs.htm [ 12-02-2004, 10:23 AM: Message edited by: tom kyler ]
I'm not completely sure on this Rick, but I don't believe that the SAT format supports any type of entity heirarchy. Most programs have proprietry type of classification or heirarchical schemes and would be impractical to maintain that info when other programs to which you would import an SAT model would have it's own organizational scheme. But in answer to your specific question, VW does not support class assignments when exporting SAT to my knowledge, and I regularly export SAT format to use for animations in other packages.
G-Pang, I've selected up to 25 lines myself (all at once) and extended them all to another line, with just two clicks total. VW can extend multiple lines with the connect/combine tool.
