139 -
Everything posted by JuanCarlos
Referenced Files and Resource Manager
JuanCarlos replied to RussU's question in Wishlist - Feature and Content Requests
Export Sheet Layer Viewport as Image
JuanCarlos replied to Kevin McAllister's question in Wishlist - Feature and Content Requests
If something like in the picture bellow works for you, it can be added through the Workspace Editor to the Object Context Menu Folder. HTH JC -
New visibility settings
JuanCarlos replied to Jim Smith's question in Wishlist - Feature and Content Requests
I totally understand, I also like to draw things one time and expect them to be graphically correct in all my plans, here is my work flow; Rules: 1.) For all objects make all attributes “By Class” 2.) There is no rule that says Stack Viewports Not Allowed. Viewport possibilities: for Layers; On/Off/Grayed, alter staking order, for Classes; On/Off/Grayed, Override Class attributes (this will only be possible if you comply with rule #1.) Some times there are several objects with the same class in different layers and there is a graphical need for some of them that are in a different layer to be represented differently, Divide and Conquer, you can stack viewports (rule #2), yes there will be some initial setup, however it will payoff when you modify things. Sample bellow: a simple roof that traverses two floors, all objects have only been drawn once. 1st floor has a stack VP for the 2nd Slab with a class override 2nd floor has stack Vp's for the roofs with class overrides Roof has Layer stacking order and class overrides HTH JC -
Would Class Override in Viewports work for you? -
Here is another idea; Do the same Wall Style as Jim Smith and set the Wall class pen attribute to none and follow steps bellow
A referenced DLVP is a container just like a Symbol, currently Vw does not have Styled Symbols and a direct connexion like the one you described is not possible, however if your interest is just a graphical appearance here is one way of doing it; 1.) Have the Unit join all the walls to the exterior and party walls as you would like to see them 2.) Select all the interior walls > Group > Convert to Symbol. 3.) Use Symbol for the units, if used in front of exterior walls the unit internal wall will appear to be cutting the exterior walls. Hope this helps JC
- 2 replies
- apartment block
- file setup
(and 1 more)
Tagged with:
Wall component "library"
JuanCarlos replied to JMR's question in Wishlist - Feature and Content Requests
Currently the best way to approach the issue is to have a wall style with all the components you normally use or are common to your area saved to your office standard folder (All Components WS), then any time you need a new wall style you can duplicate the All Components wall style and delete the unused components since it is easier to delete a component than to create a component. Hope this helps! JC -
3d, push buttons & motion
JuanCarlos replied to digitalcarbon's question in Wishlist - Feature and Content Requests
"One issue I did have with the FBX model being imported were you could see through the back of some wall so you needed to set up the file correctly" Alan, when this happens reverse the normals -
Have you tried to set classes to the different components and for the top/plan view override the attribute fill to none of the handrail class
COBie Spreadsheets from Vectorworks - Anyone doing this?
JuanCarlos replied to willcfg's topic in General Discussion
Will Go to File>Export>Export IFC Project... From the dialog box select Data>Export Options and then select "COBie/Facilities Management" from the Model View: dropdown menu. Don't forget to do the Layer Mapping before you select OK. You will have then an Ifc file, if you want to see this file in spread sheet form you would have to install the COBie Tool Kit. Hope this helps -
I would suggest to draw in screen plane mode in the DL the objects that you intent to cut and paste in to a SLVP annotations for this workflow to work
If the objects that you want to change their attributes in VP section are drawn by class attribute you can override those classes in the viewport and then you can use the eyedropper transfer these class settings from one section VP to another Hope this helps JC
Hi Amelia, Save your Slab file in the User Folder>Libraries>Defaults>Walls~Slabs and that should do it! Best, JUan
For your 2nd question I will assume what you are looking for is a half size set 11x17(45%) Printing 36x24 sheets on 11x17 paper If you are on a Mac when you select print select the tab for paper handling and check Fit to Page If you are no Windows when you select print select properties > effects and select print to fit Hope it helps
If you want to edit in section mode you may want to use the Clip Cube
Reported
You can use the "Replace with Symbol" command from the modify > Convert drop down pallet after creating the new trees in the Resource Browser
Workflow for working with constantly updating drawings
JuanCarlos replied to Sam Lee's topic in General Discussion
As Jonathan described, Workgroup referencing is intended to reference a file that you are not going to touch, however if you have the urge to fiddle with the 3rd party's file you may want to have an intermediate file where you will import the 3rd party's file > fiddle with it and then reference it, but be aware of the "BUS" If you just want to override their classes and their Layers (classes) are standard you could use the Standard Naming in the Document Settings and edit one of the users to your liking -
Lets no forget the one that comes with Vw I used it for quite some time, just had to remember to close the files when not working (lunch, brakes, phone, etc) Copy from the Log file, paste in a worksheet and pars through it.
http://www.vectorworks.net/bim/project.php?id=9
For those in 2013 you can use a script in this thread http://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Main=35797&Number=181308#Post181308
You may want to try Workgroup referencing
