138 -
Posts posted by JuanCarlos
For the Qty you will use =COUNT(Criteria) and for Percentage well that would be some percentage math from the results in column B
HTH
1
- Popular Post
- Popular Post
Just wanted to let you know that the Stair is in the Roadmap, it was an oversight!
https://www.vectorworks.net/en-US/public-roadmap?url=-486
Now would be a good time to add any particular wishes to the Stair card(s)
HTH
7
As Pat mentioned C1 has to be a number, then you can try this =IFS(C1<=1500, '5', C1>=5000, '9',(C1>1500) & (C1<5000), '8')
HTH
With the Custom Stair selected in a 3D view <Control U> (PC) <Command U> (Mac) > OK converts to 3d objects Extrudes and 3D Polygons, this allows to edit the individual pieces. HTH
@CAD Cadet Glad it's working for you, soon it will be much better https://www.vectorworks.net/en-US/public-roadmap !
@Tom W. On the bottom right set the height and width to 0
3
1
1
@CAD Cadet It is possible, it's just not the friendliest option! In the Window Tool General > Custom Configuration Options.
But don't loose hope, we are working on it https://www.vectorworks.net/en-US/public-roadmap
4
2 hours ago, Christopher Graye said:
Can't you set some criteria based on the style, @JuanCarlos?
A condition can be added in this case 'WallStyle-2' is the wall that is getting a record
2
1
@KWiley Happy New Year!
In the attached file you can find a simple small sample of a Record attached through the Data Manager and a formula applied to one of the record fields to automate an output. Reading through the thread I understand this was a manual process for you with the exception of the attached Record to the Style Object, the same can be accomplished with the Data Manager, further more and the beauty of it, is that the process can be automated through formulas (same as in worksheets) making the process faster and less prone to errors
Hint, use worksheets to check your formulas
HTH
1
2
it’s a regression, If you can please report it
Thanks
1
Stair Tool
@Christiaan Would this be close enough?
2
Can you send me the file?
Hope this sort clip can clarify the texture control in your walls.
1
Can you send me a file with an object that behaves properly or close and one that doesn't and list some parameters that you like to see
I encountered the same issue and reported it as bug, the current workaround that I found, it is that the light is aiming 90° down meaning perpendicular to the ground, if the light is tilted 0.01° then the light rotates with the symbol.
HTH
IFC Rotation
in General Discussion
Posted
If you do not want to mess with the user origin here is where you correct the rotation angle,
