JuanCarlos
Vectorworks, Inc Employee
    141
Everything posted by JuanCarlos
  1. If you do not want to mess with the user origin here is where you correct the rotation angle,
  2. You will need to include COBie in your Views
  3. Are you selecting the COBie export option? HTH
  4. For the Qty you will use =COUNT(Criteria) and for Percentage well that would be some percentage math from the results in column B https://app-help.vectorworks.net/2025/eng/VW2025_Guide/Worksheets/Entering_formulas_in_worksheet_cells.htm?rhsearch=worksheets&rhhlterm=worksheet HTH
  5. Just wanted to let you know that the Stair is in the Roadmap, it was an oversight! https://www.vectorworks.net/en-US/public-roadmap?url=-486 Now would be a good time to add any particular wishes to the Stair card(s) HTH
  6. As Pat mentioned C1 has to be a number, then you can try this =IFS(C1<=1500, '5', C1>=5000, '9',(C1>1500) & (C1<5000), '8') HTH
  7. In the Window settings, General pane, Configuration setting select the "Custom..." option, then play with with the Custom Configuration Options. HTH
  8. With the Custom Stair selected in a 3D view <Control U> (PC) <Command U> (Mac) > OK converts to 3d objects Extrudes and 3D Polygons, this allows to edit the individual pieces. HTH
  9. This Is the closest I could get using the old Custom Stair, from here you can ungroup and finish modeling it. HTH squared spiral staircase.vwx
  10. @CAD Cadet Glad it's working for you, soon it will be much better https://www.vectorworks.net/en-US/public-roadmap !
  11. @Tom W. On the bottom right set the height and width to 0 Window Custom.vwx
  12. @CAD Cadet It is possible, it's just not the friendliest option! In the Window Tool General > Custom Configuration Options. But don't loose hope, we are working on it https://www.vectorworks.net/en-US/public-roadmap Window 2 top awnings.pdf
  13. A condition can be added in this case 'WallStyle-2' is the wall that is getting a record
  14. @KWiley Happy New Year! In the attached file you can find a simple small sample of a Record attached through the Data Manager and a formula applied to one of the record fields to automate an output. Reading through the thread I understand this was a manual process for you with the exception of the attached Record to the Style Object, the same can be accomplished with the Data Manager, further more and the beauty of it, is that the process can be automated through formulas (same as in worksheets) making the process faster and less prone to errors Hint, use worksheets to check your formulas HTH Record to styles.vwx
  15. it’s a regression, If you can please report it Thanks
  16. @Christiaan Would this be close enough?
  17. Hope this sort clip can clarify the texture control in your walls. Wall Texture By Component_By Object.mp4
  18. Hi, Edit the Material and check the Report as Component Area in the Construction Tab. HTH
  19. Can you send me a file with an object that behaves properly or close and one that doesn't and list some parameters that you like to see
  20. Hi Henrique, You have to attach the IFC record to the symbol at the Resource level (Right click on the Symbol), in you case would be IfcFurnishingElementType then mark/check the IFC entities/Psets that are to be used and fill the Property Values as desired HTH
