Janis Kent
    31
    Never
Everything posted by Janis Kent
  1. quote: Originally posted by mdilday: Is there a function that will enable me to enter the length of a line and it will draw the line to that length? If you double-click the tool icon itself, a Create Line dialog box opens allowing you put in the delta X&Y of the line or to do it by angle and length. You can also place it either by coordinate location or by next click of the mouse. Many tools if you double click have these "Create Object" dialog boxes. ------------------ Janis Kent, AIA author WorksTutorial & WorksManual
  2. Paul- there is a simple way to do this with worksheets, although it will seem as if there are a number of steps involved if you have not done it before - but once you are familiar with the process, it will take under a minute to do. First, Create a Worksheet by going to the Resources palette & clicking the New button. Select Worksheet for resource type. A Create Worksheet dialog box opens for you to enter a name - give it a name - all you really need is 1 row and 1 column. When the actual worksheet opens, click in the cell & type in the = (equals sign) in the Worksheet Entry dialog box that opens. Then 2 steps left - In the upper left of the worksheet, press on the downwards pointing arrow to Paste Function - in the Select Function dialog box that opens, select Count & Done. Then press the arrow again, this time down to Paste Criteria & you get the criteria dialog box. On the left side press/drag to Symbol & then when you click the button on the right side all of the symbols will be listed in the file - just click the desired symbol & OK. The formula will be created in the Worksheet Entry dialog box - just click the green checkbox next to the formula & the formula will be entered with the correct number shown in the worksheet itself. If you add or subtract symbols, you will need to press on the arrow in the worksheet down to Recalculate. This will count all of a specified symbol in your drawing whether visible or not & whether it is within the printable boundary or not - so be careful of placing unwanted instances of symbols since they will be counted. ------------------ Janis Kent, AIA author WorksTutorial & WorksManual
  3. If you create a template file at the desired resolution, every file opened from that template will have the same resolution. ------------------ Janis Kent, AIA author WorksTutorial & WorksManual
  4. If I recall, you should download the last release of MC7. I believe it is 7.0.5. That version fixed some problems for output, on Windows.
  5. quote: Originally posted by jnr: What does one have to do to import/export between the same version of Vectorworks (8.5.2) on PC and on Mac? If the file is a template add .sta to the end of the file name rather than .mcd if it is going from MAC to WIN
  6. I would really like to see the ability to automatically create interior elevations, prefereably a linked elevation. Right now you can only get exterior. In fact, it would be really nice to be able to marquee select an area on the drawing so that the specified area can be linked, whether for an interior elevation or for an enlarged plan.
