Catmansound
45 -
Everything posted by Catmansound
Roof Dormer's don't print in Top view, PDF or Printing to plotter
Catmansound replied to Catmansound's question in Troubleshooting
Thanks Juan. -
Wall Components Not acting like I think they should
Catmansound replied to Catmansound's topic in Architecture
Thanks, capping in this way does seem to help, cheers. -
Thanks for taking the time to verify. -
Sure, I just made a file from scratch, that way we can be sure I didn't corrupt the file I've been working on, it's about 400mb or so anyway rather large to post. This file is from scratch, just the roof, dormer and a background rectangle. I created a roof with a dormer and put a rectangle underneath to see the results, same results. See attached vwx and pdf generated from the .vwx cheers, Anthony Roof dormer disappearing in viewport.vwx Roof dormer disappearing in viewort.pdf -
Thanks Jeff, I should be more specific, I'm running Dell Precision 7670 Laptop, 12th Gen i9-12950HX, 64GB RAM, nVidia RTX 4500. I should add that any combination of classes and layers that I turn on or off in that viewport, i.e. everything on, only items I want displayed on etc. still the same result. Try it and see if you get the same results. create a roof place a window in Vectorworks and explode it and make a symbol out of it (it's how you make dormers) activate that window and place it on the roof, the Dormer dialog box appears to allow you to configure your dormer create a viewport and place it on a Sheet layer publish, print or just export to pdf Make sure the viewport is set to Top/Plan View and Wireframe Background Render. let me know if you get the same result, it might be a graphics card issue, i do have 24gb graphics card, so who knows. cheers, Anthony -
Guardrail Infill "Rotate bars to diagonal" broke since last release.
Hi TomKen, thanks for the suggestion, I see that now, didn't realize there were two fence tools, I'll look into that for now. Much appreciated. -
Thanks for the feedback. My system is as such: Dell Precision 7670, Windows 11, 12th Gen i9-12950HX, 64GB RAM, nVidia RTX 450 GPU. My real concern is the end wall to be honest, I got around the missing components part. Thanks,. Anthony -
Hi, I created a railing and rotated the infill bars at 45% in one of the previous releases of Vectorworks. I just downloaded and installed the new version of Vectorworks yesterday, and now the Railing page for Guardrail-Infill Rotate bars to diagonal "degrees" field is missing. The button for the "Rotate bars" is still there, but the field where you input the "diagonal degrees" is missing and as a result, any "save" of any other feature of the railing will delete the bars if you have the "Rotate bars" button checked. Please fix, see my screen shot as I can't recreate the diagonal bars again.
Catmansound posted a question in Troubleshooting
I'm having this really strange thing going on, I create a window and turn it into a Symbol, I place the window symbol onto a roof to make a dormer. I then create a viewport to a sheet layer and set the viewport as Shade view. When I print to my plotter, or make an Adobe PDF file from that sheet layer, the dormers don't show up, they disappear. Attached is a screenshot image of what is displayed on screen from the Sheet Layer, and the pdf file from Export pdf, showing what I mean. same thing happens when I print directly from Vectorworks to my HP T530 plotter. I'm running Dell Precision i9-12950HX, 64bg ram, Nvidia RTX 4500 GPU, Vectorworks Version 2024 Update 4 (Build 747709) thanks. Anthony Saved from Sheet Layer.pdf -
Hi, this is sort of strange and a bit weird, and I'm wondering if it's my graphics card, here's what's going on. open the attached file and note the wall which I've configured for 3 wythe brick and one finish side of gyp bd. The wall has two windows in it. Now, to see if you can reproduce what I'm seeing, delete one of the windows, just one, either one. Notice that the face of the gyp bd before you delete the window takes on the brick pattern, but once the second window is deleted, the face of the gyp bd takes on the attribute I've assigned it in the components. The outside facing you is supposed to be gyp bd finish. Also, notice the edge of the wall, we are restoring a historic building and some wall ends are exposed, so when I wrap the end bricks notice how they always seem to scale or at least shift vertically differently than the face of the wall, a bit of a problem when trying to zoom in and expose the wall ends. like I said, these are really weird but it's driving me crazy, thanks again for all your help in this. Wall Component Issues.vwx
Giving up om 2024 and looks like 2023 from now on
Catmansound replied to MartinFahrer's topic in General Discussion
I received a response from Vectorworks yesterday about this, they said that this is being addressed in the next update, good to know they read and react to these posts. -
Hi, I dock the Basic on the left of the screen, and below that I dock the Tool Set, and below that I dock the Attributes menu. My display is 2560X1440. Plenty of white space below tools. I position the Tool Sets & Attributes so that there's plenty of white space below all the Basic icons and there's still plenty of space below the Tool Sets Icons. When I close down Vectorworks and restart it, the Tool Sets is smushed down, an the scroll bar appears, I have to reposition up again. see attached image I made, thanks and hope this helps. -
Same here, drop down menus don't retain last size state when you quit and restart Vectorworks, they always shrink to smallest curled up size, this has been happening since first release of 2024 and continues to this last update. Neither do tool set and attributes menus, they always resize to some default postion when you relaunch Vectorworks. -
I'm interested in creating a custom window where the custom configuration options have upper double hungs about .4 sash scale factor, which is fine, but then I want 1 horizontal mullion on the top panes, and 2 lower mullions on the lower panes. Any suggestions? I supposed I could create two rows but then the sash isn't right and it's really goofy, so really need a double hung window with differing mullion options from top to bottom, thanks.
Rendering with windows, doors and extruded object VW2024
Thanks Zoomer, I'll try that. -
Got windows to render finally. Since I had started this file in VW2023, I think there might be a glitch when rendering those objects in 2024. I created a new window from scratch and it renders as expected, so then I used the eye drop pick up tool to copy the attributes from the new window I just created to the one’s already in the file that were created in 2023, all the components now render with proper texture I applied. Windows have had a few issues in initial release of 2024 that were fixed in the newest SP I just updated the other day, so maybe one more closer look at window objects for next update. -
Hi, I'm having trouble figuring out why I can't get window components (sills, jambs, shutters, etc.), or extruded objects to render when I apply textures. All I get are wireframe on those components. The glass in the windows seem to default to a transparent glass texture it seems, but when I apply textures to the window components they don't render. The door frames and sills seem to render exactly the texture I apply to them. I can't get faces of extrudes to render either, just get wireframe. I've tried every render option I can find and nothing seems to work. Windows 10, Nvidia RTX 1080, 32gb memory. Thanks for any help. Anthony ok, somehow extrudes rendered ok, created from scratch, and worked fine. So, hey I tried that with windows, 😞 darn that didn't work, still can't get window objects to render. -
I find this whole aspect both very useful in converting 3D model files into a set of construction documents, and also very frustrating in that the plan view where you created the section line once linked to a viewport no longer displays the section line marker in the plan view. I logged this in as a bug, and received a reply that's just how it works. In other words, they've given us a great feature, but only followed through half way. Need to generate a 2d floor plan viewport showing the section line/section-elevation marker, link that marker to a section viewport and have that section line appear in the floor plan so that a construction document set can show where the section is taken. I'm told to explode the section marker for it to show up in plan view, but that defeats the purpose of the section line functionality, cause if you decide to move the section line to show something slightly different in the building section, guess what you've got to start over, sounds like a but to me.
I'm having a similra problem with all our machines, we run Windows 7, all Dell Precision laptops and workstations. Try the OSB/Detail, same problem as JoshW is having, but this happens with just about every object we use from the Linear Materials tool.
Export file to dwg, worksheets not included
good thought, but didn't work, thanks any way. -
Sure, we have a couple of systems running, one has 4 gigs memory, 512 nVidia graphics card on Windows XP SP3, the other 2 gigs memory, 256 nVidia graphics card on Windows XP SP3. The point of posting is not to complain, sorry if it came across that way, but to hopefully address to the development team that I believe there is a user interface speed problem within the graphics engine, and that hopefully it would get addressed in the next update. Anthony
Good point, sorry 'bout that. we're working with Windows XP and Vectorworks 2009. (my system has 2 gigs of memory and a 256 nVidia graphics card, the others have 4 gigs and 512 nVidia cards) Ok, thought it was something we were doing, so I experimented and here's what I found. We just installed 2009 and have been opening files from the previous version, 12.5. (I skipped 2008). As it turns out, must be something in the way that worksheets were created in 12.5 or earlier that prevents the worksheet from being converted properly into 2009 and then exported to dwg. Turns out we have a few worksheets on our construction documents that we'll remake from scratch, will take a little time, but such is life. Sould take care of the problem. Anyway, thanks for the feedback. Anthony -
I suppose the more complex software get, the more robust our computers must be to keep up. 4Gigs of RAM is alot to ask for when all you are after is a simple 2D vector based drafting tool. I could understand that for the 3D modeling and rendering portion, but my experience with 2009 thus far is that the graphical user interface is the issue. one solution I found was to turn off all those selection and preselection color coding stuff. I do move around the drawing faster now. If I were to guess, I would say that Nemetsheck has some tweaking to do with their graphic redraw engine. I remember this exact issue with AutoCAD around R13. It took a lot of hot under the color customers voicing their complaints for Autodesk to rev up the graphic engine. I think Nmemtschek needs to do the same here. Other areas slow are large viewports, bringing up the worksheet edit window and selecting fonts. I have a large number of fonts on my system, and I work with Adobe products, Quark, MS products, AutoCAD and others, and don't have the lag I have with 2009. Hopefully they are listening and will tweak the user interface portion of the graphics engine.
If you export a file containing worksheet to a dwg format, the worksheet is not exported, does anybody have any knowledge of this?
