sfatelier
194 -
Posts posted by sfatelier
Thanks! That did it!
I am having problems trying to generate an extruded object above finish floor height. Do I have to do this with layers. I don't seem to be able to do it in the object info pallete. Is there somewhere else I could do this? Thanks
Thanks! I'll try that.
I applied a texture to the floor of a drawing and when I do a fast radiosity rendering, the texture appears fractured. Is there a way to cover the entire surface with this texture? Thanks!
Now that I have textures, I applied one to an extruded form. Nothing happens. I still get a wire drawing. Even when I render, it is invisible. Any suggestions?
Thanks.
Thanks, that did it!
I recently upgraded Renderworks to v.12 with a serial number. Now that I'm ready to apply a texture to an extruded object, I can't find the included textures in the resource browser. I've tried importing them but I can't import what I can't find. Help!
I received a serial number to unlock the Renderworks tools in V. 12 Architect. I can't seem to figure out how to use this SN to unlock the Renderworks features. Can anyone help me? Thanks,
Does anyone know if you upgrade Vectorworks Architect, do you have to upgrade Renderworks as well to keep it? I am missing Renderworks after upgrading Architect to v. 12.01 Thanks.
I upgraded v.11 with Architect and Renderworks but only upgraded Vectorworks with Architect to v.12. Now I don't have Rendoworks with v.12 after the upgrade. Is there a way to have the v.11 of Renderworks with v.12 Architect? Thanks!
Thanks, I'll try it!
How do I know what style is asoociated with each number without a graphic representation? Thanks
Thanks, that did it! Any explanation on the fact that some walls behave that way and others don't?
OK I'll try that. It's odd that this wall (8" CIP concrete) is one of the Vectorworks standards and it's not set up to render as solid. Thanks
I tried that but when I select the wall, the attributes becomes grey and I can't change the fill or line settings. What's with that?
Thanks! I'll try that. I kept focusing on the object info palette.
I don't know why some walls appear solid and others as wireframes when I render a perspective in open GL. Can anyone explain to me why this occurs. I have used the walltypes from the program (v. 12 - pc). Thank you!
Thanks!!! That did it!
For some reason, instead of x,y & z, I have j and i in my coordinate boxes in the toolbar. Any suggestions on how to change it back to x,y & z? Many thanks!
Thanks! That did it. Is there any way to change the font on the label as a preference?
Dear BC, I have version 12, Architect, on a pc. Sorry for the confusion. I did manage to change them by changing the wallstyle to "unstyled". Previously with an assigned style, the component option wasn't available. With the change to "unstyled", I was able to change it as you directed. Thanks all for your help!
I have version 12.
I'm mystified but when I try to use the object id label function, when I click on the object, the label is placed way outside the area, nowhere near the object itself. My order of steps is exactly as the manual instructs me to do. Help!
Extruding Complex Form
in General Discussion
Posted
I have outlined an area using poly lines and straight lines. I would like to extrude this. I tried grouping and trying to convert to a polygon but no luck. Is there a way to combine these elements and group them to extrude? Thank you!
