DDD
111 -
Everything posted by DDD
@Tamsin Slatter Thank you! Then what is the common practice to stop the grading at the property line if I also need to place multiple grade limits on site?
@bgoff Thank you!
Hi, I am having problem using grading limit, please see attached exhibit. Is there anyway I can tackle this? Thank you.
@Pat Stanford Thank you Pat. All the lineworks are drawn in this VW file. But Markdd's solution works, thank y'all for the help.
@markdd Thank you Mark. I change the polyline plane mode to "layer" and it works. But I don't understand why it is "3D" as default. And it doesn't give me the "layer" option at the beginning, I need to change it to "screen" first then I can see the "layer" appears. I'll pay attention to those configurations next time, thanks for the help.
Hi I am have trouble with those basic tools again and I don't know how to trouble shooting. The file and snapshots are in the attachment. I am using VW 2021 I have this red polyline and I want to split it in those tangent points, I select split tool and click on the line but nothing happens. If I drag the red line to another random place, the split tool works. It just doesn't let me split the line in its original place. Then I am trying to duplicate the green rectangle 10 times along the red line, it gives me confusing result as the duplicates fly all over the space instead of following the path. if I check "center on path " it will work better but in this case I don't want the rectangle to be centered on path-------it should on one side of it. These tools have been failing me for multiple time and I don't know where I did wrong, please help, thank you. 20210113 landmark study 1.vwx
Referenced Class Visibility Control in Different Viewports?
DDD replied to DDD's topic in General Discussion
@Boh Thank you Boh. -
@Pat Stanford Thank you Pat. -
DDD posted a topic in General Discussion
Hi all. I am having trouble with the reference file. For instance, I referenced a cad file and set it on "xref" class, it has two layers (A & B). Then I am trying to set up two viewports on the sheet layer. Viewport 1 will only show layer A and viewport 2 will only show layer B. However, using the visibility tool, I can only control to turn on/off the "xref" class, I don't have further control on layer A/B in the viewport setting. If I go back to design layer and turn off/on A/B, it will affect both viewports. Is there any solution? Thank you. 2021 Landmark -
Hi, please see attached snapshots. I would like to pdf the drawing with transparent image fill. The sheet layer and design layer look good but the final pdf ignores the transparency (grass & asphalt area). Is there any print settings I could've paid attention to? Thank you.
Hi, please see attached images. Is there anyway I can make the text line type as smooth as the original one? It's giving me those zigzags around corners. Thank you.
Can I edit objects info through worksheet database using a fomula?
@Peter Vandewalle Thank you Peter, I'll check that out. -
@Pat Stanford Thank you Pat! -
Hi I got a question, please see attached snapshot, The column F is linked to existing tree info field X Column E is automatically calculating the correct field X value Is there a way to make column F automatically replicate column E, so all the tree info field X can be updated quickly instead of me typing them manually. Thank you!
Hi I have a question regarding the worksheet cell formatting. Let's say the document unit is set to 'feet', and I have an one-feet long line that I want to put into a report reflecting its length. Is there anyway I can show its length as "12 inches" instead of "1 feet" in the worksheet without changing the document unit settings? Thank you.
How to set standard front/right/top views to a random oriented object?
@Pat Stanford Thank you very much! -
@michaelk Thank you!
Hi please see attached file, I am trying to fill all the round holes in this slab. I want to work with the clip/add surface method, however when I cover those holes with circles and run "add surface", the circles disappear and the holes remain the same, any help? Thank you. slab fill.vwx
@Tom W. Voted, thank you.
Hi all, how can I adjust the texture orientation on a slab object? The OIP doesn't give me that option.
@Pat Stanford Thank you!
Hi, is there any way I can quickly apply a fomula to a whole column? Like the "cell dragging" in Excel? Thank you.
