883 -
Everything posted by hollister design Studio
@JonKoch thanks, found it. For anyone wondering where to find the gate flip controls that are not on the OIP... Flip controls are located in the reshape tool under the "ELEVATION / EDIT MODE" With that mode selected if you click on the gate control point you get a dialog box that has "Flip Across Fence" and "flip Along Fence" You unfortunately can select only ONE option, and then you need to click OK to activate. If you need both, you need to do this twice - not as clean as the door flip... Hey VW help pages, it took me a couple of reads in the help pages to figure this out. There isn't ANYTHING relevant and searchable for gate "flip" - until you hit the "Click to show/hide the parameters" button. I tried cntl+F on various pages and eventually found the info after giving up and just reading everything starting at the top.
@Katarina Ollikainen quick question, how does one flip the swing of a gate? direction of a fence?
Thanks for putting this in writing Pat. I wish this was more clearly stated in the help pages... If they had opened with "using number values only - no thousands separator". I have had so many instances in the last 4 years, struggling to get a simple "SUM" formula to work, banging my head against the proverbial wall... all because I had a thousand separator!
What happened to my Navigation Palette??
hollister design Studio replied to hollister design Studio's question in Troubleshooting
thanks @Christiaan, all good now. -
hollister design Studio posted a question in Troubleshooting
What am I not doing correctly? I imported a Velux skylight symbol. Selected the roof class and layer as active. Double clicked the skylight in the resource manager (in the 'selected file' mode.) Hovered over the roof until it was highlighted. Clicked and then clicked to set the angle. The skylight just sits perpendicular to the roof with no cutout. Also tried from Top/Plan but the roof will not highlight. Video capture: Skylight problem.mp4
Update 1.1 for 2024 stuck at 99%
hey @JuanP where should we upload the UpdaterLog? -
@adriandurlesterI closed everything, restated computer and now VW is showing 1.1 too. Not a good thing to see an update stuck with no way to exit or restart from the app. Having to resort to killing it in the Task Manager is a bit frightening... -
I've been having issues with the new update on windows 11 The updater keeps getting errors and stopping - when I finally got it to move forward by restarting it many times, it got stuck at 99%. I can't quit, cancel or launch (without using the task manager to end it). Thoughts?
I would like the class and layer OIP dropdowns to show all the classes and layers when I click on them. In 2023, when I clicked on or off the "all layers" / "all classes" button on the bottom of the dropdown menu, VW remembered the setting and opened up in that mode the next time I used the dropdown menu. In 2024 it always has the button clicked on and the filters visible, and I have to click the button off to see the full list of layers/classes. How do I get the "no filters" setting to stick like before?
Formatting works sheets currently involves a lot of right clicking | opening the 'format cells' menu | switching to the appropriate tab| adjusting settings | closing the menu - then seeing if what you adjusted does what you had intended. ...and if not, redoing all the opening and closing of menus and tabs. It would be nice if formatting options where in a excel-like "ribbon' and all you had to do was select the cells and click the appropriate formatting buttons in the ribbon. This would certainly save some needless clicking.
Thanks E|FA - same in Landmark - but I don't see a place to edit icons. Here is the Tools menu->Workspaces->Workspaces... menu - followed by me clicking on "Edit..." HDS TIGHT to open the Workspace Editor Where do I go from here to add back those icons? Maybe things are different in Architect and/or Mac? again thank you!
Desktop shortcut to start different workspace
hollister design Studio replied to Camille Dupont's topic in General Discussion
This would be nice. I have an 'on site' setup for my surface tablet so I can (almost) work with a touch screen and a "standard" custom workspace for my workstation. Like you, when I open my "onsite" workspace on my workstation, all my palettes are off. When I open the "standard" workspace on my tablet - all hell brakes loose! If I'm in the office I can attach a mouse and a keyboard and get things working again - but if I'm already in the field... It does seem the workspace is tied into the file - saved with the last open instance - it sure would be nice to be able to choose workspaces per machine. -
The snazzy new 2024 tool set icons got over written for workspaces that I brought in from 2023. Is there anyway I can keep my old workspaces but get the fancy new icons? new icons in the Landmark workspace: Icons imported with my custom 2023 workspace: The tool icons were not affected and are the new 2024 versions .
This was working fine moments ago... now it doesn't. I have some callouts with attached records. I use them for an overly complicated materials schedule (I seem to be always trying to make thing simpler and succeeding in making them complicated...). Callouts are on specific classes and have specific keynote prefixes depending on the material or hardware being spec'ed. The work sheet has criteria that use class and prefix to define what goes where. In the above case the Callout has an "H." prefix and a "H.2." identifier. And the callout is showing up on the worksheet in the proper place under the proper criteria. BUT the identifier is showing as "C.2." not as "H.2." And this flips with sometimes all the identifiers are "c." and sometimes all the identifiers are "H." and sometimes the don't have a letter and are just the number. Here is another set with the H" callouts showing correctly, but the "C." callouts showing as "H." or just a number This also shows my criteria: All of these works sheets and callouts have been working fine for at least a year - until today they all of a sudden went weird on me... Ant thoughts?
Can VW make use of an i9?
hollister design Studio replied to hollister design Studio's topic in Hardware
@_James I went with the i912900HK and it seems to work pretty well with a 32"monitor and with VW and Photoshop running concurrently. It's my first Dell and I have to say I'm pretty happy. Not that I haven't had issues.... I had crazy overheating starting about 10 months after I purchased it... computer was ramping up to 85C at idle! It would even wake itself up in the middle of the night and then shutdown from overheating - with nothing running and no one in the office. Oddly it cooled right down to 45C if I was running VW or Photoshop. Talked to tech support for about a month trying to figure it out. In the end they replaced the motherboard and that fixed the issue. I was impressed that they sent someone out to my office (I'm pretty rural and it's a multiple hour drive from the nearest city) and that they scheduled the onsite tech for the next day. Pretty solid customer service.
