ztijnf
    10
Everything posted by ztijnf
  1. I'm super confused. The two objects you edited I can edit as well. But when I try to change the colours of other samples (in your file) it doesn't work. - Set it in the right class - Click on the colour and click 'By Class' - Leave the fill style to solid (leave it there) - Go to the organisation menu and change the colours of your class - Click 'automatically adjust settings' End result: Nothing changes. If you don't see anything wrong in these steps I'll just leave it at that. Thank you for all your help. I really appreciate it!
  2. Hi Stan, Could you upload your edited file? I think I understand what you're saying but for some reason it doesn't quite work for me yet. And again, a big thanks for your help!
  3. Of course! Thank you for your help! Sample file.vwx
  4. Hi @Pat Stanford, Thank you for your fast reply! This is what I initially thought too. However, this doesn't seem to work. I have created the class 'Rood': And I changed it's colours to pink: Am I missing something? (Sorry about it being in Dutch, next year I'll update it to being in English..)
  5. Hi, I have seen someone edit the background colour of his standard 'dev_label_center' in different colours in the same schedule. I thought it was a genius new possibility, but somehow I can't seem to do it. Maybe is's because of the fact I don't have connectcad, which would make sense. (I just get schedules from people to take a look at and edit in VWX. I don't use it often enough to actually buy the license). But it would be great if it was possible and someone here would be able to tell me how. I have attached an image to explain what I mean. These are both 'dev_label_center'.
  6. Hi, I'm working on a stage that's a circle and I would love it if there's an option to distribute/duplicate my layher symbol along the path of a circle. This would save me a lot of work. If there are any questions regarding the question, do not hesitate to ask!
  7. Hi all, Thanks for the answers! I will adjust it in the symbol definition. I think that's the best way after all. This was a great first experience on the forum. I'm really thankful for all the answers and I'll be back 🙂
  8. @Alex Sagatov, thanks for your reply! It doesn't totally answer my question though. (My explanation isn't great either, agreed) My question is if I set the insertion point of the symbol at the corner of the wooden floor as you can see in the picture, would it be possible for this not to insert as Z=0? But for example as Z=20cm? Thanks for the help!
  9. Hi, I am working on some Bleachers and I ran into a problem. The only snappoint that would work is in my symbol at Z=20cm as you can see in the picture. So, if I put this bleacher in the venue it will be 20cm below Z= 0, even though it says Z=0. Is it possible to use this snappoint and tell Vectorworks to put it higher relative to the Z value? I realize my explanation is a bit vague but I don't know how to properly explain it otherwise.
