Stéphane
    133
Posts posted by Stéphane
  1. I had the same issue and figured out it was a scale/dpi ratio issue.
    See bellow :
    scale 1:200 / 300 dpi --> ok
     TILE 200 300dpi.pdf
    scale 1:200 / 1200 dpi --> ok
    TILE 200 1200dpi.pdf
    scale 1:500 / 300 dpi --> solid grey
    TILE 500 300dpi.pdf
    scale 1:500 / 1200 dpi --> ok
    TILE 500 1200dpi.pdf
    Mind these settings :
    - Layout raster setting
    - File>Print raster setting
    - File>Export To Pdf "Convert Pdf To Image" and "File Size Reduction" settings
  2. 11 hours ago, Pat Stanford said:
    It is quite possible that you don't use more than one color for a Linotype, but I will pretty much guarantee you that there are people who rely on the ability to have multiple colors in their complex linotypes to get the drawings they want.
    You are right, it is good to have several ways of using a tool. So you would say that complex linetypes work as they should ? Would you confirm that for each new fill color, you need to duplicate the complex linetype ? By the way, it also means you cannot override its fill attributes in a viewport.
  3. In my opinion, it shouldn't work like that. A complex linetype is a linetype and it should work as a basic linetype. The pen attribute controls the color of a basic linetype. The pen attributes should also control the color of a complex linetype (fill+pen). I cannot see a good reason why it shouldn't work like that. You never use more than one color anyway for a complex linetype.
    As a workaround I filled my complex linetype with lines... Not sure if it's a brillant idea tho 🙂
    Step 1 : Add lines in your custom complex linetype.
    1994678562_Capturedcran2021-08-2717_12_36.thumb.png.10f2fb00205768c60ee78c5c9c95737d.png
    Step 2 : Make it thicker
    1659498601_Capturedcran2021-08-2717_14_06.thumb.png.eae469367d971facba5267e5c911e7a3.png
    Step 3 : Profit...
    1360410934_Capturedcran2021-08-2717_14_31.png.b3f13b52e010f7c2a20535acac7aaaed.png      463124849_Capturedcran2021-08-2717_14_40.png.20e8ea323eb58bad7991d9ab254c15ca.png
    • Like 1
  4. Hello,
    I have created my own complex linetype with some polygons. These polygons have a fill color and a pen color.
    Then, when I use my new complex linetype in the design space with Polyline for instance, I can only change the pen color and the line thickness but not the fill color of the polygons that I used to create my custom complex linetype. This means I need to duplicate my linetype for each new fill color I need ? Is that the normal behavior ? Is there a trick to be able to change the fill color as well ?
    Creating my complex linetype :
    446822921_Capturedcran2021-08-2709_35_09.thumb.png.311144ad5142d27d3a92e1a5b3f6f8cb.png
    Drawing a Polyline with my new complex linetype (as you can see I was able to edit pen color but not fill color as I would like to) :
    496571724_Capturedcran2021-08-2709_35_48.thumb.png.0a21727342c697da759cef8867986d06.png
  5. 9 minutes ago, line-weight said:
    Is it because you want to show eg. ground floor for each building, but each building has its ground floor at a different level? In that case, I might try and use several viewports laid beside each other but I can see that might get complicated.
    Exactly. Several viewports yes, but look, I want to do architecture, not viewports management 🙂
    Things should be simple and efficient. Actually I don't like to spend time on drawings. The less time I spend on drawing things the happier I am. Thats why I moved to BIM. And before that, to CAD
    22 minutes ago, line-weight said:
    For me, I find it very difficult to get 'proper' (graphically speaking) plans using top-plan. I expect which method is best depends on what kind of buildings you are dealing with. If they are quite rectilinear with multiple storeys then maybe top/plan works OK. But for example, as soon as I have rooms inside pitched roofs, or anything where I've had to model a lot of stuff manually from solids (old buildings with funny stairs, say) top/plan becomes pretty much useless to me.
    I have to say, I don't know how I would deal with old buildings renovation. No clue. I would probably keep it simple and do things in 2D. Not worth it to model everything in 3D. The 3D information exist already.
  6. 5 hours ago, line-weight said:
    I think basically you want everything on your basement layer to be viewed as a "top" view rather than top/plan view - is that right?
    Exactly.
    I don't think a top/plan viewport is able to do this, and it's one of the reasons I don't really use them, and use a horizontal section instead (which has its own, different issues).
    It is actually possible but as far as I know only in the design space. Hence actually my question, if it is possible to do it in the layout space by overriding the setting which is greyed out – I don't know why... Look at the screenshots below, taken from the design space, so it's not exactly what I want. I just want to unlock the greyed out setting Enable Cut Plan at Layer Elevation in the layers override... It is so closed of being a super useful setting !
    Also, I am aware of horizontal sections, but as you said, they have their own issues. In my case, I cannot use them on this specific project.
    1059042872_Capturedcran2021-07-2116_08_26.thumb.png.019415fa5b72af55d83e482f94966382.png314590921_Capturedcran2021-07-2116_07_41.thumb.png.fabc1be4efd352051673aab6928a24c0.png^
  7. Hello,
    In a 2D plan Viewport, 2 layers are activated : Ground floor and Basement. For some reason, I would like to override the cut plan elevation of my Basement in order that only my Ground floor would be drawn as cut. The Basement would be drawn as seen from top / non-cut. Problem : This option is greyed out in my Layers overrides window.
    The general idea is that I would like to see on my Groundfloor plan informations from my Basement plan but seen as if the cut plan would be on my Groundfloor (actually like any proper plan).
    Please, see the screenshot below to see exactly what I mean...
    321944622_Capturedcran2021-07-2109_45_37.thumb.png.e11a8c7e8d66b9ce24a721c6e7b4788b.png
  8. On 12/14/2020 at 7:04 PM, line-weight said:
    While we are on the subject of roof faces:
    Is there an inconsistency in the way class visibility works, compared with floor slabs and walls, or am I doing something stupid?
    For example: if I have classes:
    object_wall
    object_roof
    object_floor
    material_A
    material_B
    - Then I have a wall, with 2 components, one is assigned to material_A and the other to material_B
    - I put the wall object in class object_wall
    - Then I set class material_A = visible, class material_B = invisible, class object_wall = visible
    - I set the wall object to render by component
    - Then what appears is the wall, but only with the component set to material_A actually visible.
    - Of course, if I set the class object_wall to invisible, nothing appears at all.
    But if I follow the same procedure with a roof face object, something different happens.... the component that is supposed to be invisible is visible.
    Is that something that someone else can replicate?
    Is your issue related to this one maybe ?
  9. Please, find bellow a drawing showing my 3 buildings to illustrate my post.
    1. What I observed
    - It is not possible to have 2 stories at the same level (for instance A0 and B0 on the same level)
    - It is really annoying (and I'm trying to stay polite here) to set these stories one bye one when you have 12 buildings, 50 stories, 70 layers. In one window they are listed by name, in another by level; I had to print my layers manager and highlight my stories like in the '80s to see what's happening. After approximately 801'153 clicks I got what I wanted.
    2. My questions
    - How to set properly a file and their stories with multiple buildings in order to export it to IFC ?
    - Is it really mandatory to assign stories in order to export an IFC ?
  10. On 3/6/2018 at 4:25 PM, Pat Stanford said:
    Draw a 2D poly on top of your slab and choose Add Surface from the menu and you will get a bigger slab.  Clip Surface and Intersect Surface work as well.
    What would be nice, is being able to select 2 slabs and then choose Add Surface to combine them exactly like you would do it for two 2D poly... This is on my wishlist 🙂
    • Like 3
  11. I am well aware on styles, sorry if my question was not clear enough. Let me elaborate :
    Different tools can give you the same kind of objects. For instance to create a door, you can generate it through the tool "Door and Window" (we give it a style named A) or through the tool "Doors" (we give it a style named B).
    In my case, I started a project using one tool to generate doors but then realized another tool was better.
    So my question is this one :
    Would it be possible to replace the door style A (from "Door and Window) by the door style B (from "Doors") ? Via the OIP as you suggest, it is, I believe not possible.
  12. 20 hours ago, markdd said:
    There is nothing baked-in that I am aware of. However, do you know about the Class Visiblities button in the Organisation Dialog? This will give you an overview of class Visibilities in Viewports and a whole lot more besides. This will help you manage this kind of either/or scenario.....
    I will have a look at it... Thank you for the tip !
  13. Hello,
    Scenario :
    I have objects A and objects B placed in a class X.
    I have layouts U in which class X is activated and layouts V in which class X is not activated.
    I realize now that it would be better to have objects A placed in class X and objects B placed in a new class Y.
    I want my new class Y to be activated in layouts U but unactivated in layouts V (like it was the case for class X).
    What I do
    When I create the new class Y, I told it to be unactivated in each layout. I then manually activate it in each layout where class X was also activated.
    My question :
    Is there a more clever way to do it ? The idea would be to tell class Y to be active on layouts where class X is active.
