AG74
    8
Everything posted by AG74
  1. Update: After much tugging of chin hair, I found if I cut the existing plants and repasted back into the document, they appear at the correct height.
  2. Hi can I throw a similar question in here? I have always designed my 3Ds on a flat surface for simplicity and as such have never needed to send plants to surface of a 3D site model. I now have to do the dreaded contour 3D design! I created a site model and added it to my design. But all the plants are still sitting at Z=0 elevation and the site model starts at 6m. How do I tell the plants to conform to the site model elevation? To clarify, I created a site model on a new layer and dropped it into my finished 2D design. Any new plants I create are sitting at correct elevation but the existing planting is all at Z=0.
  3. Thanks Pat - Jeff's workaround above is doing the job for now
  4. How do you select tags and thus edit obj info palette? If I try and select tags the whole plant is selected - doesn't alter the viewport render of the tag
  5. You are an ideas man Jeff! I will do exactly that for now thanks mate. Adam
  6. Hi how do I get plant tags to display in the viewport without the sketch effect? In fact it would be good to be able to apply the sketch effect solely to the site plan and hardscape layers... Thanks
  7. Right - fixed it y'all. In each plant symbol settings, the tag class hadn't been assigned (the default class was 'none'). Once I assigned plants-component-tag as the tag class I was able to control tag visibility in the viewport. Simples.
  8. Hi, I'm trying to turn off plant tag visibility for a viewport. When I uncheck plant-component-tags nothing happens, plant tags are still showing. VW 2019 thanks
