hi katie.
its on screen, to be honest i have not tried printing it out yet, so i will check.
when a simple rectangle is drawn, the edges are sharp 90 degree angles and not slightly rounded. any polygon, or line drawn has a rounded edge.
When i a basic rectangle is drawn, the corners are sharp 90 degree angles. when a polygon is drawn or a line, the ends of the line are rounded. how can i make everything have sharp edges. is there a way of changing the pen from a rounded to a square one???
PROBLEM FIXED!!
this is how.
delete all printers installed on your machine, go to add new printer and let windows install the printer not the driver from HP.
go to print and its fine, vectorworks no longer crashes! thanks to everyone here for there added support and thoughts on this issue.
regards,
chris.
Hi
i have the same problem. i have been told its because the printer doesn't supposrt postscript files from vectorworks. However it is possible to use adobe press ready to convert the printer script file to a post script file. On looking into this its seems aparent adobe do not longer make this peice of software. i too am looking for answers to solve this problem. can anyone help?
