Hello all,
I have been working on creating some Heat Recovery Ventilation (HRV) 2d/3d symbols for projects, and I think I have generally got the workflow down well enough but there is one aspect that is a bit annoying in terms of time/steps it takes. To make these HRV symbols, I model the whole thing - ducts included - in 3d, and then use the "Generate 2d from 3d Components" command to create the 2d views of the HRV symbol for plans/sections. My issue is that as far as I can tell, I have to individually switch to each different 2d view and then "Generate" the 2d symbol for each separate view. This is a bit frustrating when I have 5 different views (top, left, right, front, and back) that I want to update anytime after I make alterations to the 3d symbol. Maybe this is a minor complaint, but it would be really nice if there was a way to generate all 2d views from the 3d model with one command/click instead of having to do each one individually. I'm sure this is something Vectorworks could easily handle as it shouldn't be much/any extra work for the program, and it would save the user time and effort. Is there any way to do something like this already that I am missing or haven't discovered yet? And if not, it would be really nice to have that functionality added. Again, maybe this is something of a niche issue, but I'm sure there are others out there who would benefit from something like this. I suppose there might be a way to do this via scripts? It might be relatively straightforward but I don't have any experience creating or even using scripts, so I have no idea how that would be done.
Any thoughts? Thank you very much.
