Tess
    5
Reputation
0 Neutral
Personal Information
  • Location
    Australia
  1. Thanks so much for the intel Jeremy 👍 I was definitely not presented with the confirmation dialog so will contact support - thanks for this 🙂
  2. Hi there, I was attempting to remove a single file from my resource manger favorites category (I selected the item and then file->remove from favorites) and somehow all of my favorites files disappeared? I didn't select remove all favorites. Either way - is there any way to restore these?? There was alot of data in there (plant symbols, in particular) that will be too painstaking to restore manually. Also - is there a way to back this up in future? Any help appreciated!
  3. Apparently I can right click and export the plant resource, choosing to replace the symbol there.
  4. Thanks so much for your reply Mike - and for the correct terminology! Yes, it is the same plant resource I'm working with, so I don't want to replace it with a different one. I'd like to simply swap the 2D symbol only of said plant resource for a different, pre-existing symbol from the resource manager. I took a look at the edit 2D component but that looks like I need to essentially make my own symbol, which I'd rather not do for time saving reasons (and there are plenty of symbols to choose from already so it feels like unnecessary work on a deadline). Does that make sense? For context, if it helps: I have numerous existing plant resources in a previous VW file that I wanted to use in a new file so I didn't have to create each plant resource (and enter all the data) all over again, but the symbols are too similar to plant resources I've created in my new file already. I appreciate your help!
  5. Hi all 🙂 Is there a way to change the plant symbol once you have all the data entered for a plant? I have a few that look too similar but can't seem to find a way to just change out the symbol for a different selection without just deleting it and creating a whole new plant (have attached screen shot in case it's not clear what I'm referring to). Thanks in advance for your help!
