4,939 -
Everything posted by Tom W.
You can use two Windows set to Opening configuration to make the holes in the Walls instead. This doesn't result in a line in 3D: But you do get one in Top/Plan... Not sure if there's another way...
Before I even look at the Picket Fence tool can I just say you deserve an award for creating a 'Delete DataVis Legend' script? 😃
Create Class From Object
Tom W. replied to ericjhberg's question in Wishlist - Feature and Content Requests
Difficulties learning the basics of site modelling
Tom W. replied to demetris ktorides's topic in Site Design
And this one: https://university.vectorworks.net/mod/overview/view.php?id=5243 -
I agree with this but I think I'm right to say that it only affects a small minority of tags: those where you are inputting data in the tag AND where the data being inputted has fewer characters than the placeholder text. Generally speaking I think most tags people use are taking the data from the object automatically + therefore what the placeholder text actually says is far less important (I don't think I have any tags which are affected in the way you describe + I have dozens of them). However I do think it would be a worthwhile enhancement as it's clearly a real pain in the cases where it is an issue (this came up once before with someone else). I think the answer might be however to have the option in the Edit Data Tag dialog of replacing the placeholder text with a description of your choosing (for the purposes of making that dialog more legible) rather than restricting the placeholder text to displaying the default value for the field. I think it's quite important for layout reasons to have complete flexibility over the placeholder text (how many characters it has) as it can really affect how the tag looks in terms of how the constraints work.
- 1 reply
- 1
Putting Hanging Position Labels into a Circle/Square/Hexagon
Tom W. replied to Darin K's topic in Entertainment
Persevere they are essential. Post a file if you want someone to help set it up -
These dims determine the size of the Image Prop. So most of the time you'd set them to the 'real' size of the object, but in the case of a Plant I'm not sure it makes an awful lot of difference since you set the size parametrically afterwards...
I think it is a one-off object that was converted into a hybrid symbol solely in order to give it a Top/Plan representation. Hybrid symbol was chosen over Auto Hybrid to have more control over the 2D representation. I guess the advantage of an auto hybrid is that if you do find you need to edit the size of the object you just need to edit the 3D component + the 2D will follow automatically whereas with a hybrid symbol you need to edit the 3D + 2D components separately. However in the grand scheme of things we're still only talking a few seconds...
Not centre on import: the 'Centre Drawing on Internal Origin' command.
The workflow is covered in this video: https://university.vectorworks.net/mod/page/view.php?id=1349
Landmark - Plant Schedule displaying image of plant
Tom W. replied to J.Aspect's topic in Marionette
When I tried it yesterday I found I could add images to some of the plant styles but not others. For some reason those with the coloured circle graphics I couldn't get the image to display in the worksheet e.g. yet those with the 'normal' graphics I could e.g. Couldn't understand why so left it hoping someone else would explain... -
The parameters you want to be the same for all instances of the style should be set to By Style (bent arrow icon). The parameters you want to be able to edit on an instance by instance basis should be set to By Instance (pair of sliders icon). This is in the style settings. Then in the settings for instances of the window you will see the By style parameters are greyed out + can't be edited + those which are By instance can be edited.
I'm not sure this method will be suitable because in the case of a hybrid symbol it will result in one of the components being lost as you can only Command-K either the Top or the 3D component. @Darin K I would just edit the symbol definition: youve said it's only very simple geometry so it should only take a couple of secs.
I don't centre my site/geometry on the Internal Origin. I have a georeferenced template file where the IO is central to the geographical area I work in. Because of the nature of where I work, all of my projects happen to fall within a 5km radius of the Internal Origin so I don't need to do anything: I can just draw wherever I want based on the real world location of where the project happens to be. But if I had a project outside that 5km boundary I would just re-centre the drawing on the Internal Origin which would in effect move the geometry AND the User Origin together, relative to the location of the Internal Origin. So my geometry would have the same relationship to the User Origin - would still have the correct coordinates - all I'd have done is moved it + the rulers relative to the IO. I believe best practise in BIM - when coordinating with others - is to agree a common Internal Origin point - like you say, a nice round number - as a belts + braces way of ensuring everyone is in the right location - and this can be done as above using the 'Centre Drawing on Internal Origin' command. But otherwise the IO can be wherever you want it as long as your geometry is within 5km of it.
No you can't I'm afraid. It was introduced in VW2021 or even VW2022 I think...
The 5km limit relates to the Internal Origin not the User Origin.
But isn't it useful to be able to take coordinates from your models? Like when setting-out on site? The only reason I have e08m numbers for my Internal Origin offsets is because I didn't centre my geometry on the Internal Origin particularly carefully as I didn't need to as I'm not coordinating with anyone else using the IO. I could have easily ensured it had nice round numbers if I'd wanted but I didn't need to: all I was concerned about was ensuring that my geometry was within the 5k safe working zone or whatever it's called. You don't need to move the User Origin in order to have nice round numbers for the IO offsets. You can put the IO wherever you want it (or rather move the geometry wherever you want it relative to the IO). Surely the easiest + simplest thing is for everyone to set their User Origin to the British National Grid rather than moving it around from project to project...? Then agree a common IO location for each project?
I was definitely advised very strongly to do it as a matter of course. So if something does go wrong, troubleshooting is easier as you can immediately discount the template files + concentrate the search elsewhere... 😁
I will remember this when I'm doing it for VW2024 thank you! Do you recreate template files as well each time?
Using the 'Document Georeferencing' settings which are set to OSGB 1936 / British National Grid by default in UK licensed files. It's something I set up once in 2020 + haven't gone back to since...
What original DWG? This is a georeferenced template file. But if I import a georeferenced DWG into it the import settings automatically default to the 'Align with Internal Origin' option + the imported geometry will be correctly located relative to the User Origin. Which is precisely what I want. Then once I've designed the building I can give the surveyor the coordinates for the foundations + he can mark them out on site. Because we're all working to the same coordinate system.
My User Origin is aligned with the OSGB36 datum i.e. located south west of the Scilly Isles. My Internal Origin is in Norfolk...
No. My geometry is centred on the Internal Origin.
If you use Subtract Solids on a Wall you will turn the Wall into a Solid Subtraction which you generally wouldn't want to do. You can use a Door or a Window set to 'Opening' configuration though (to make a hole).
