Ron Craighead
    1
    Never
Reputation
0 Neutral
Personal Information
  • Occupation
    Draftsman
  • Homepage
    baukunst@in-tch.com
  • Location
    Bozeman, MT USA
  1. ere are a couple of things that may make this program easier to use: 1) Changing layer heirarchy in the Layers Setup window: You should be able to just click and move the layer to the desired position instead of going to the "UP" "DOWN" buttons, thereby eliminating those buttons. 2) Moving a selected object: You should be able to move a selected object by going right to the arrow keys, instead of hitting 'command + comma'. This is annoying. This is one of the most commonly used commands and over the course of a day increases significantly the amount of commands necessary to initiate a simple function. Currently, if you select an object and hit the arrow keys, the screen view changes. This command is already available in the tool pallette.
