23 -
Reputation
3 NeutralPersonal Information
Location
Switzerland
Recent Profile Visitors
Also, there ideally should be an option to assign (in the roof object or style) different hatches based on roof rotation — e.g. 0-180: hatch I; 180-360: hatch II, or 0-100 HI, 100-200 HII, 200-360 HIII... any number of assignments over any range, plus a fallback. So as to give the user maximum flexibility.
I got the same issue. To my knowledge, this is a missing feature, or rather: a bug — logic would want the same principle as walls would be followed ("hatch rotates in wall").
@Antonio Landsberger & especially @DomC many thanks for your responses. Unfortunately I'm not a very frequent user of forums (maybe I could improve in this regard somewhat?) – but appreciate you taking the time to respond. Agreed that too much "idiot-proofing" prevents flexibility, and I'm all about being free to code whatever I want. However it's important that bugs (as @DomC you seem to have confirmed) should still be reported and corrected... if a given functionality is provided as part of a proprietary package (vs open-source), we have to rely on the vendor to make adjustments and corrections. Anyhow, many thanks for reporting, and looking forward to seeing if this node can be updated 🙂
What's your preferred Cloud?
MrPilot replied to PVA - Admin's question in Wishlist - Feature and Content Requests
That would justify our office transitioning from NextCloud to OwnCloud. Any updates on this Vectorworks-side? -
Anyone from Vectorworks care to answer? The code behind this node is buggy and we really would like this to work. It's bloody tiring to get stuck for hours on such topics, and a great reason to switch away from Vectorworks. @sbarrett @DomC @ComputerWorks
@Dendecko that [the "Forward" node in your file] worked for me as well, thanks a lot!
Hello, I'm bumping the subject as well. This is hugely important, especially when thinking about AI and Web integrations. You can't properly run that on Windows or even Mac servers!
+1 This software is too good to run on such a crappy OS as Windows. I've got a Mac and a PC, but need to run Vwx on the PC as well. Also, a Linux version would be HUGELY beneficial for future developments in my company.
Bump. Any chance of Owncloud / Nextcloud getting added? 🙂 -
MrPilot changed their profile photo
I have the same issue. I have a structural plan of a fairly complex roof, where for manufacturing purposes I have each repeating structural member encapsulated in a symbol. There is a record format attached to that symbol so that things like dimensions, material, cost, etc. are saved at symbol definition level. The problem which I have is that data from the symbol definition isn't accessible in tables, so the only workaround I found is to attach two different record formats: one to the symbol definition, with instance-specific data (e.g. unique ID, finish, timber grade, etc.), and another one to the 3D object within the symbol definition, this time with definition-specific data such as dimensions, which don't change as the symbol is a static resource in this case. A related issue is that tags don't work in symbols within symbols: i.e. in Layoutebenen (should be something like layout layers, i.e. 2D working drawings), in viewports, I can only attach a tag to the "parent" symbol, whereas I would like to be able to attach it to the child instance, and for the tag to access the data stored in the child instance symbol definition.
I'm self-hosting through a NextCloud provider (migrating from Cloudamo to Hetzner). -
Having the option to clip in 3D would be even more fantastic. The expected behaviour would be to retain all original hatches / surfaces, and where a cut occurs, a cut hatch would appear as the resulting surface. N.B. Such a tool should definitely work on groups, not just single items. Feel free to reach out to me personally to discuss details.
Hello! I find this to be an absolutely necessary tool! To give a current example: 3D section with added 2D details, e.g. tiles: Evidently, the tiles should be cut by the pink rectangle for better aesthetics. This is where a clip option would have been great! Kindest regards, Konrad
Had a lot of issues with Dropbox, besides their prohibitive pricing (at least last time I looked)... so working with success on NextCloud for a while now. Maybe you should also add OwnCloud to the list (NextCloud is a branch thereof). -
Black line appearing in final render in viewport
MrPilot replied to Helen Palmer's topic in Rendering
I was able to solve this issue by applying a texture to the component which was rendering with black lines, in this instance the glazing in the windows. Window type [1.] does not have a texture assigned to the "glass" component, whereas window type [2.] already does. I hope this helps someone.
