Santino Di Renzo
17 -
Never
Reputation
0 NeutralPersonal Information
Occupation
Designer
Homepage
Hobbies
Location
New York City
Preferences - Not coming up
Santino Di Renzo replied to Santino Di Renzo's topic in General Discussion
yes, it happens with Classic and Standard workspace. I have to reinstall. :-( -
No. I created a workspace as a copy of the V11.5 default -
Whenever I select VECTORWORKS PREFERENCES from the menu "vectorworks" or from the File/Preferences the dialogo box does NOT appear. I tried to change the settings from the Workspace at not avail. Am I doing something wrong?
I have been using ARTLANTIS for over 3 years. PROS: 1-simple tools 2-fast preview (real time) I handle models of over 4 millions objects 3-integrated with vectorwoks as plug in (I use classes to assign materials) CONS: 1-poor image mapping 2-poor interface, I prefer dial box to sliders for precise adjustments 3-obsure mother company muy choice to use it was mainly as an alternative to renderworks which back thenwas so slow.
I am not sure this is the right place to post this but I am curious about the new Artlantis R. Is it woth it to buy it? I use the Artlantis 4.5 and it is so unsatisfying. thank you
thank you all, i did finally manage to open the file. Very annoying procedure.
Is there a plug in available to open a minicad 6 file into VW 10.5? I hear i have to reinstall VW 8 to bridge it. Is it posiible to avoid that ? thank you
is VW11 compatible with dual processor? in other words can I keep working while exporting a massive 3d file to artlantis for which now takes about 20 minutes? santino user since 1994 -- VW 10.5.1 dualG5 2GHZ 4GB RAM OS 10.2.8
quote: Originally posted by CipesDesign: Santino, the first thing to try is VERIFY & REPAIR permissions (found in the DISK UTILITY app, in your utilities folder, in your applications folder). After doing both, which may take a while, restart your machine, then restart VW's. If that doesn't work, call tech support! Peter Hi Cipes, I did that and it worked out fine. however, it is not the first time I have to do that. Is this a bug Nemetschek is looking into fixing? it is SUPER annoying... thank you all for helping
Hi, I am working on a 2D doc and I am esperiencing a unprecedented problem. a simple object ( i.e. a square) cannot be moved by the pointer (selection tool) by just dragging it, like I usually do... It is driving me mad, please help...
Adjusting Palette Width under 10.5
Santino Di Renzo replied to slick-50's topic in General Discussion
Slick, there is no picture in the link you provided. -
Snap to Object difficult on G5
quote: Originally posted by Katie: Are you using the same document on both computers or are you comparing results with different files? Have you tried to run Disk Utility First Aid on the G5? Katie, yes I used he same file on both machines. I did run the Repair Permission as suggested in another topic in this forum. Things seems to run better. thanks for your help. regards S. -
Hong, while you are in the worksheet click on the little arrow pointing down just below the red "X" . The sub menu should pop out and scroll down to insert-> row or column. done try it regards S.
Katie, I am using VW 10.5 on MacOS 10.2.8 on G5(x2) and MacOS 10.2.3 on Powerbook G4 Titanium. Regards S. -
To RonR I have not get to that level of problems yet. The issue I am experiencing is while working in 2D. But thanks for the reply. S.
