Hi, I use VW as a 2D drafting app, not BIM. With that said, we have office standard 2d symbols to tag equipment, that are page based, so the printing size remains consistent through out different scales.
I need to add leaders to those symbols to point out elements in the drawings. Is there a way in VW that leaders are added to 2D symbols, without the need to add a separate leader line? I would like to avoid grouping after the fact.
Also, I insert the symbols in the annotation viewport and, if for whatever reason we need to change the scale of the viewport, the fact that the leader is separate from the symbol makes them not adjust properly. See attached jpeg showing gap between symbol and leader.
I'm aware of the callout tool, that can create a similar symbol, but as it works right now, it leaves open a lot of user customization, vs using a 2d "locked" symbol. Also, it does not allow the leader and the wrap around the text to have a different line weight. Does the call out tool allow to add a custom wrap around the text, with a fixed length/ size?
Other option is to set up a label tool that is not ID related, and that will allow customizing the label format. Is that tool currently available in VW?
Thanks,
